Pine64 Playbox case STP conversion
(07-28-2016, 10:22 AM)xalius Wrote: The problem with soldering the switches in is that the mechanical guide posts are soldered into the ground layer of the board which immediately transports the heat away from the point of contact. You need a powerful soldering station (I use a Weller WS81 for example) and a solder pen that is constructed in a way so that all the heat is actually delivered even with small SMD tips (this is were cheaper soldering solutions usually fail...). Make sure you heat up the area where you want to make the joint before touching it with the tin, but if it takes more than 2-3 seconds then your station and/or pen+tip combination are to weak/wrong. If you do more rework on boards with large ground/supply planes investing in a cheap hotair and preheater station usually does wonders....
Thanks for the info, I will be sure to invest in a nice soldering station soon!
Pine64 Playbox case STP conversion - by RockE - 07-09-2016, 08:13 PM
RE: Pine64 Playbox case STP conversion - by RockE - 08-07-2016, 11:58 PM
RE: Pine64 Playbox case STP conversion - by tllim - 08-10-2016, 05:19 PM
RE: Pine64 Playbox case STP conversion - by RockE - 08-22-2016, 04:47 AM
RE: Pine64 Playbox case STP conversion - by RockE - 07-26-2016, 06:54 AM
RE: Pine64 Playbox case STP conversion - by RockE - 07-28-2016, 08:37 PM
  Are the Pine64 Acrylic Open Enclosures Stackable? abhinava 5 9,743 09-17-2020, 06:41 AM
Last Post: dabou
Big Grin Super Mario case [NOW WITH UPDATED STL-FILE (April 27.)] Tarjei85 37 65,097 07-23-2020, 05:31 AM
Last Post: devendraraju
  Made a case for the Pine64 with Audio DAC installed kodachrome 1 4,016 11-12-2019, 04:52 AM
Last Post: xalius
  Playbox with DAC llungster 0 2,758 04-02-2019, 09:02 AM
Last Post: llungster
  playbox case ribbon cable too short pinoosh 7 12,492 02-22-2019, 03:24 AM
Last Post: GaryFunk
Video 7" LCD wooden framen enclosure for Pine64 *UPDATED WITH killor 12 20,093 10-12-2018, 03:08 PM
  Clear case PIne 64 with VESA100 LIPO , RTC holder, and mini fan holes killor 6 11,691 08-05-2017, 07:15 AM
Last Post: killor
  New Pine 64 Screen Case from C4Labs Dustin_C4Labs 11 19,232 07-18-2017, 10:39 AM
Information Giving the Pine a trunk, a Playbox pedestal tommypine 7 10,280 07-16-2017, 01:51 AM
Last Post: selina3
  A case with active cooling for 1Gb pine64 ishwest 5 10,171 06-28-2017, 04:05 AM
Last Post: ishwest
