Are the Pine64 Acrylic Open Enclosures Stackable?
I was wondering if it's possible to stack the acrylic enclosures (https://www.pine64.org/?product=pine64-a...-enclosure) to hold multiple Pine A64s.
From what I see, this might be possible? I suppose I can use the bottom piece repeatedly to mount the individual boards and just use one single top piece at the very top?
(01-02-2019, 01:47 PM)abhinava Wrote: I was wondering if it's possible to stack the acrylic enclosures (https://www.pine64.org/?product=pine64-a...-enclosure) to hold multiple Pine A64s.
The original design didn't take stackable into consideration. However, if you able to special screw that can link the poles together, it can becomes stackable.
I'm trying the same, and I'd love to know the spec of the large hand-tighten screws that serve as legs -- my intention is to get an longer version of them, and saw off the head to tie together two acrylic cases.
(07-15-2020, 01:47 PM)lbruno Wrote: I'm trying the same, and I'd love to know the spec of the large hand-tighten screws that serve as legs -- my intention is to get an longer version of them, and saw off the head to tie together two acrylic cases.
I used M8-1.25x16mm grub screws successfully to stack two of these enclosures:
https://imgur.com/a/Zka1qfb
Obtained mine from Farnell.
Thanks on the info.
What are the dimensions of the standoffs delivered with the pine64 acrylic box - http://files.pine64.org/doc/guide/PINE64..._Guide.pdf ?
Thanks on the info.
  Made a case for the Pine64 with Audio DAC installed kodachrome 1 7,283 11-12-2019, 04:52 AM
Last Post: xalius
Video 7" LCD wooden framen enclosure for Pine64 *UPDATED WITH killor 12 32,756 10-12-2018, 03:08 PM
  A case with active cooling for 1Gb pine64 ishwest 5 16,616 06-28-2017, 04:05 AM
Last Post: ishwest
  Acrylic case with Lipo Holder and 2 Tactile push button included killor 9 22,428 10-24-2016, 08:18 AM
Last Post: killor
  Pine64 DOA - and they don't care mldavies 4 14,435 10-13-2016, 03:57 AM
  Pine64 Layer case modmypi 2 9,030 10-04-2016, 02:45 AM
Last Post: modmypi
  Anyone wanna swap enclosures ? stephen0205 2 7,530 08-27-2016, 09:13 AM
Last Post: stephen0205
  Pine64 Playbox case STP conversion RockE 14 31,193 08-26-2016, 08:05 AM
Last Post: pspina3rd
Photo LEGO Enclosure for PINE64 w/LCD Yardle 4 10,910 08-24-2016, 09:28 AM
Video Acrylic enclosure for PINE A64 killor 71 146,610 08-12-2016, 06:53 AM
Last Post: killor
