Giving the Pine a trunk, a Playbox pedestal
Information
Hi, i designed a pedestal for the Playbox Enclosure.
Now Pine looks like a sweet tiny Desktop. Big Grin
It's 3D-Printed.
Update 22.04.2017
Version 1.0 now has a hinge to adjust the visual angle.
  • A stacker pocket is added to the base.
  • Full access to the Pine connectors.
  • The hole for the Ethernet jack is also there but closed with a very thin layer, you can cut it out for to use it.
  • An additioinal hole in the bracket, say for a power-cable jack to the Euler bus.
Update 23.04.2017
The STL's are available there:
http://repables.com/r/847
Update 26.04.2017
V2.0:
Added a version of the base which includes a holder for a Nokia MD8 active speaker box.
This speaker will be plugged in the earphone jack.
Have fun... Cool
Nice pedestal! :-P
Can you put the design up up on thingiverse or something, in case other people want one too (or perhaps attach the STL if the forum lets you)?
Nice work, and yes, 3D printing data would be nice Smile
Final version 1.0 is ready, see first post of this thread. Rolleyes
Very nice! I love the addition of the hinge, and the tray to collect random loose bits in! Wink  Thank you for sharing!
(04-20-2017, 04:45 AM)xalius Wrote: Nice work, and yes, 3D printing data would be nice Smile
STL's are now available for download, see first post.........
V2.0:
See first post.
How did you make it? It is amazing.
Photo C4 Labs Pine 64 Cases (Standard & LCD) Bluphire 95 240,328 11-02-2020, 08:43 PM
Last Post: Little_Johnny
  Playbox with DAC llungster 0 4,990 04-02-2019, 09:02 AM
Last Post: llungster
  playbox case ribbon cable too short pinoosh 7 20,177 02-22-2019, 03:24 AM
Last Post: GaryFunk
  Clear case PIne 64 with VESA100 LIPO , RTC holder, and mini fan holes killor 6 18,729 08-05-2017, 07:15 AM
Last Post: killor
  New Pine 64 Screen Case from C4Labs Dustin_C4Labs 11 30,242 07-18-2017, 10:39 AM
Rainbow (Cluster) Modified Playbox Enclosure Progress predominant 3 10,516 06-17-2017, 01:29 AM
Last Post: pfeerick
  playbox and camera jpfaubert 1 6,640 03-07-2017, 12:51 AM
Last Post: MarkHaysHarris777
  How is the battery Supposed to be mounted in the PlayBox enclosure? dbarbee 2 9,913 02-12-2017, 10:17 PM
  Do Pine sell a tablet back cover? brucezepplin 4 13,095 12-20-2016, 08:24 AM
Last Post: Bluphire
  Playbox battery charge jdmwrx94 12 30,465 12-20-2016, 07:19 AM
Last Post: Toriless
