Broken eMMC boot
the easiest solution will likely be to remove the bottom cover and use the switch to disable the emmc. then you can boot into the SD img, flip the switch to enable the emmc again, and rebind it so the SD install sees it (bind commands can be found in the wiki)
Broken eMMC boot - by annahellrothsparent - 04-27-2022, 07:43 AM
RE: Broken eMMC boot - by tophneal - 04-27-2022, 08:35 AM
RE: Broken eMMC boot - by annahellrothsparent - 04-27-2022, 09:49 AM
RE: Broken eMMC boot - by tophneal - 04-28-2022, 07:31 AM
  Manjaro Sway Theme Broken Eighty8 1 335 03-08-2024, 08:41 AM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,250 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,352 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 462 12-07-2023, 03:11 PM
  Boot Order in Pinebook Pro food 8 1,396 11-23-2023, 07:37 AM
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 2,035 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Emergency Mode Boot Hotkey? jiacovelli 20 4,784 06-02-2023, 01:32 PM
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 3,582 04-01-2023, 03:22 PM
Last Post: TRS-80
  Fix for Armbian not booting on PBP from eMMC agreenbhm 7 3,974 04-01-2023, 02:58 PM
Last Post: TRS-80
  Suspend/Resume Broken with Bootloader on SPI Flash xp19375 2 1,223 03-24-2023, 04:25 PM
Last Post: srs5694
