PBP won’t boot from eMMC after Debian update / Tow-Boot installer won’t boot from SD
[quote pid="109500" dateline="1651172012"]
Then I tried your last (imdb.test) suggestion. This produced something more interesting. I’m afraid I have no idea how to point GHex to sector 64 so I tried a search for 3b 8c dc fc but that did not produce anything. There is human readable information in the ASCII column but nothing that means much to me..
[/quote]
chroot will not change device enumeration
attached mrfixit bsp uboot (ver2.0),, if it works,,, if not send me msg with email addy
For output use seek,,, idb seek=64 (default bs=512(B)), uboot seek=8 bs=1M, trust seek=12 bs=1M
(example: dd if=trust.img of=/dev/mmcblk2 seek=12 bs=1M)
(input uses skip)
to convert sectors to Bytes, *512,, so 64*512,, but this is decimal, ghex uses hex
so 0x200*0x40 = 0x8000
use kcalc for simplicity
RE: PBP won’t boot from eMMC after Debian update / Tow-Boot installer won’t boot from SD - by wdt - 04-29-2022, 12:54 PM
  Debian on Pinebook Pro u974615 7 1,340 03-31-2024, 10:11 AM
Last Post: u974615
Exclamation 'failed to open panfrost' after system update using archarm Puckla 1 380 03-01-2024, 06:46 PM
Last Post: Puckla
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,245 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,344 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 459 12-07-2023, 03:11 PM
  Boot Order in Pinebook Pro food 8 1,379 11-23-2023, 07:37 AM
  install debian on pbp jsch 7 4,176 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,646 09-07-2023, 09:38 PM
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,063 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 2,033 08-21-2023, 09:08 PM
