PBP won’t boot from eMMC after Debian update / Tow-Boot installer won’t boot from SD
(04-28-2022, 11:04 AM)wdt Wrote: Since in OP you said there was a green led (I assume no SD inserted) there must be something on emmc
When no uboot (really idbloader) can be found, there are no leds, you think it is dead
So, you must have done something wrong
Point ghex at /dev/emmc (mmcblk....) and go sector 64
idbloader ALWAYS (all versions) has file signature 3b 8c dc fc
This is how the boot rom 'knows' that is 'right' code (and to stop looking)
or dd if=/dev/emmc of=idb.test bs=512 skip=64 count=512  (idbloader varies,, 160K-210K)
Yes, there is a green LED when booting without an SD or with the Tow-Boot installer SD.
Yesterday I dd’d the emmc (mmcblk2) while chrooted into the emmc. I tried again just now while booted into Debian 11 from SD with the emmc mounted. The result was the same: Only 00’s in the display pane and dots in the ASCII column.
Then I tried your last (imdb.test) suggestion. This produced something more interesting. I’m afraid I have no idea how to point GHex to sector 64 so I tried a search for 3b 8c dc fc but that did not produce anything. There is human readable information in the ASCII column but nothing that means much to me..
RE: PBP won’t boot from eMMC after Debian update / Tow-Boot installer won’t boot from SD - by Pino64 - 04-28-2022, 12:53 PM
  Debian on Pinebook Pro u974615 7 1,315 03-31-2024, 10:11 AM
Last Post: u974615
Exclamation 'failed to open panfrost' after system update using archarm Puckla 1 378 03-01-2024, 06:46 PM
Last Post: Puckla
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,243 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,336 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 457 12-07-2023, 03:11 PM
  Boot Order in Pinebook Pro food 8 1,345 11-23-2023, 07:37 AM
  install debian on pbp jsch 7 4,154 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,631 09-07-2023, 09:38 PM
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,061 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 2,028 08-21-2023, 09:08 PM
