Tow-Boot, a new U-Boot option for Pinephone Pro and other devices
#51
(04-21-2022, 06:00 AM)wibble Wrote: The multiboot image is built to use and take advantage of the features of megi's p-boot. It doesn't have the config file that tow-boot looks to for the kernel, initrd, boot args etc. so tow-boot doesn't find anything that it knows how to boot. Even if the partition layout is something tow-boot could read, and you translated the p-boot config for the boot options to the format tow-boot uses, I don't think you'd have a way to select which multi-boot option you wanted as tow-boot doesn't have a GUI on the pinephone. It's the wrong tool for the job - stick to p-boot for multiboot.
Thanks for that explanation! I was thinking “yeah, of course that makes sense and I’d completely forgotten that Megi’s p-boot was what enabled his multiboot menu...” so I shouldn’t expect it to work unless Megi were to make some changes to his multiboot image.
But then I thought: how come Tow-Boot correctly booted the multiboot menu from the microSD card install and let me select which distro/OS I wanted to launch?
If I’ve understood your explanation correctly, Tow-Boot shouldn’t have been able to “see” anything to boot from the microSD card? So my experience should have been the same as with the multiboot install on the eMMC?
RE: Tow-Boot, a new U-Boot option for Pinephone Pro and other devices - by 3460p - 04-21-2022, 08:32 AM
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 16 1,942 4 hours ago
Last Post: diederik
  Connect external devices via USB martin@h4ck1ng.me 5 779 02-15-2024, 10:23 PM
Last Post: u-kidjp
Brick Recovery without Tow Boot b34ux 10 1,389 02-02-2024, 07:07 PM
Last Post: reky
  A Btrfs Image for Arch SXMO on the Pinephone Pro mburns 2 848 11-23-2023, 08:44 AM
Last Post: mburns
  Rhino Linux does not seem ready for the PinePhone Pro. mburns 2 981 11-23-2023, 08:39 AM
Last Post: mburns
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 1 715 11-07-2023, 09:44 AM
Last Post: mburns
  Seeking Contributors: Apache NuttX Real-Time Operating System for PinePhone Pro lupyuen 2 1,736 09-14-2023, 07:23 PM
Last Post: lupyuen
  What to do if your PinePhone Pro does not boot fxc 19 19,498 09-10-2023, 03:19 AM
Last Post: fxc
  Pinephone(pro) modem bug / shortcomings MadameMalady 2 2,466 06-19-2023, 03:40 PM
Last Post: MadameMalady
  Cannot update new PinePhone Pro bent 6 3,521 05-15-2023, 02:43 PM
Last Post: alaraajavamma
