Tow-Boot, a new U-Boot option for Pinephone Pro and other devices
#23
(02-25-2022, 12:55 AM)janjaapmeijer Wrote: Somehow that doesn't work for me.
I have flashed the SPI image to the microSD with:
sudo dd if=spi.installer.img of=/dev/mmcblk0 bs=1M oflag=direct,sync status=progress
and then keeping the RE button pressed whilst pressing the power button, gives me a red light in the top left corner of the phone followed by a yellow light.
The next thing is that manjaro starts up.
1. "of=/dev/mmcblk0", are you sure this is the right device? It's usually /dev/sdX on a PC and /dev/mmcblk1 on the PPP.
2. I've used the following procedure: hold power button for a few seconds with battery removed, then install battery, then hold the RE button pressed and plug in the power cable.
RE: Tow-Boot, a new U-Boot option for Pinephone Pro and other devices - by aigilea - 02-25-2022, 08:01 AM
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 16 2,374 04-28-2024, 01:52 AM
Last Post: diederik
  Connect external devices via USB martin@h4ck1ng.me 5 886 02-15-2024, 10:23 PM
Last Post: u-kidjp
Brick Recovery without Tow Boot b34ux 10 1,587 02-02-2024, 07:07 PM
Last Post: reky
  A Btrfs Image for Arch SXMO on the Pinephone Pro mburns 2 911 11-23-2023, 08:44 AM
Last Post: mburns
  Rhino Linux does not seem ready for the PinePhone Pro. mburns 2 1,031 11-23-2023, 08:39 AM
Last Post: mburns
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 1 764 11-07-2023, 09:44 AM
Last Post: mburns
  Seeking Contributors: Apache NuttX Real-Time Operating System for PinePhone Pro lupyuen 2 1,793 09-14-2023, 07:23 PM
Last Post: lupyuen
  What to do if your PinePhone Pro does not boot fxc 19 19,922 09-10-2023, 03:19 AM
Last Post: fxc
  Pinephone(pro) modem bug / shortcomings MadameMalady 2 2,506 06-19-2023, 03:40 PM
Last Post: MadameMalady
  Cannot update new PinePhone Pro bent 6 3,599 05-15-2023, 02:43 PM
Last Post: alaraajavamma
