Installing debian on pinebook pro (deb installer/emmc)
(01-26-2022, 03:14 PM)ljones Wrote: Ok I think I'm going to leave this one for now. I don't have any experience with towboot or uboot really and I also don't have anything like a serial cable for the pinebook. Guessing really it is best left until debian's installer can install uboot ok.
I did look at the partitioning on the inbuilt emmc and I have two partitions, the second is normal linux but the first is fat32 and about 200MB or so.
ljones
If you don't feel safe doing it - don't do it. But just as a reality check - considering it seems every ARM device has its own version of U-boot, and even often its own method of installing it (e.g., on RPi it's just a file on a bootable FAT32 partition vs specific sector location on Pinebook), it will probably be a long while before Debian installer will properly support fully automated installation without any manual steps. Considering Debian for ARM has been around already since early to mid 2000s, it is likely going to be a very long while. If you're unwilling to risk (which is not much of a risk if you don't install anything in SPI flash but install U-boot onto the first 16MiB of SD or eMMC storage, like I suggested), then your best bet is to use something like Daniel Thompson's script (search around the forums here; there should also be a link in the wiki) or Armbian images.
This message was created with 100% recycled electrons
RE: Installing debian on pinebook pro (deb installer/emmc) - by moonwalkers - 01-27-2022, 11:57 AM
  Debian on Pinebook Pro u974615 7 1,222 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,693 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,203 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,285 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 89,660 12-08-2023, 11:25 PM
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 430 12-07-2023, 03:11 PM
  Boot Order in Pinebook Pro food 8 1,301 11-23-2023, 07:37 AM
  install debian on pbp jsch 7 4,135 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,590 09-07-2023, 09:38 PM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,428 08-31-2023, 04:20 PM
Last Post: TRS-80
