Vanilla mainline Debian 11 (Bullseye) on the RockPro64
I don't live in an English-speaking country, so I am not able to convey the most delicate nuances.
In addition, my English skills are extremely poor. Please keep that in mind first.
Now, let's get down to business.
Since you've already tried "Manjaro" & "Armbian", I'll use that as an example.
If you look at the file structure of each distribution yourself, you can check the contents.
 In the case of "Manjaro",
  /boot/extlinux/extlinux.conf ...
 For "Amabian", it is
  /boot/boot.scr ...
These boot files are directly interpreted and executed by "u-boot".
*) This is a rough analogy, but these files are equivalent to the configuration files of "GRUB".
If you have a specific reason to use GRUB, that's one thing.
Otherwise, you don't need to use GRUB (which is poor quality) to boot Debian,
you can just boot it the same way as any other distribution.
If you can provide the exact version of "u-boot" you are using, and whether or not you have a "serial console",
I can tell you exactly what to do.
However, I don't know your "separation of /var etc..." will have any negative effect.
*) You can do without the "serial console", but it will make a difference in the amount of work to change the "boot-loader".
RE: Vanilla mainline Debian 11 (Bullseye) on the RockPro64 - by t4_4t - 10-01-2021, 07:48 PM
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 1 591 03-25-2024, 12:12 PM
  yocto for RockPro64 Fide 1 760 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 2,703 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 84,195 08-11-2023, 11:13 AM
  How to enable CoreSight ETM trace on RockPro64 shpark 0 616 05-21-2023, 11:34 PM
Last Post: shpark
  How do I enable Pine touchdisplay as display on Debian? Thisone 0 582 04-23-2023, 11:02 PM
Last Post: Thisone
  Rockpro64 Dead on arrival? quixoticgeek 1 995 03-12-2023, 06:55 PM
Last Post: quixoticgeek
  RockPro64 boot questions misterc 3 1,653 01-13-2023, 06:21 PM
Last Post: misterc
  A fix for Bluetooth audio stuttering on the RockPro64 raph 2 1,721 01-03-2023, 06:53 PM
Last Post: raph
  Is some u-boot required on the SPI for installing debian with the official installer? callegar 1 1,385 10-25-2022, 10:07 AM
Last Post: ratzzupaltuff
