A fix for Bluetooth audio stuttering on the RockPro64
I've bought the wifi+blueooth module for the RockPro64 board (https://pine64.com/product/rockpro64-1x1...-0-module/).
I have been struggling to make Bluetooth audio work with it. It stuttered a lot, but yesterday I found a solution. Please test it and report back, I need feedback from a few people so I can submit a kernel patch with enough confidence.
Quick explanation: A patch that fixes the stutters on ROCK Pi 4 boards, also based on the rk3399 board with the same BCM4345C5 Bluetooth device, also on UART0, has been submitted last November: https://patchwork.kernel.org/project/lin...tions.com/
This fix sets the correct right max-speed and compatibility configurations for the Bluetooth device to work correctly. It is already present for the Pinebook Pro. The same fix needs to be applied for the RockPro64.
I'm using Armbian, so the following instructions might need to be adapted for other distributions, though the fix not to be specific to Armbian and the instructions might be generic enough.
I attached 3 files to this post. Please remove the .txt extensions when downloading them. Here's how to use them.
Testing quicky
First, I only tested this on linux 5.18. This is not the default kernel version on Armbian for the RockPro64. The default kernel is 5.15. To install version 5.18, you can use the armbian-config tool which will install the linux-image-edge-rockchip64 kernel. 5.15 might work but I haven't tested it.
So:
  • Backup your stuff. We are messing with boot files.
  • If you haven't already, install linux 5.18 (the linux-image-edge-rockchip64 kernel, which can be installed using armbian-config)
  • Download the rk3399-rockpro64-v2.dtb and rk3399-rockpro64.dtb files attached to this post. Remove the .txt extensions.
  • Then, as root (add sudo as needed):
cp /boot/dtb-5.18.0-rockchip64/rockchip/rk3399-rockpro64-v2.dtb{,.bak}
cp /boot/dtb-5.18.0-rockchip64/rockchip/rk3399-rockpro64.dtb{,.bak}
cp rk3399-rockpro64-v2.dtb /boot/dtb-5.18.0-rockchip64/rockchip/rk3399-rockpro64-v2.dtb
cp rk3399-rockpro64.dtb /boot/dtb-5.18.0-rockchip64/rockchip/rk3399-rockpro64.dtb
And then reboot. Be aware that any kernel upgrade will probably erase these files and you'll need to copy them back after upgrade.
These files actually come from a kernel build, so if you want, you can recompile the kernel with the fix.
Recompiling the kernel
The previous instructions are sufficient to use the fix. However, if you may want to recompile your kernel with this fix.
Apply the attached patch. I'm testing this on kernel 5.18. The patch should cleanly apply on versions 5.18 and 5.19. I've not tested this on 5.15. On Armbian, you can download the kernel sources using apt install linux-source-5.18.0-edge-rockchip64. You'll find the kernel sources and the config used in Armbian for the RockPro64 in the /usr/src folder. The following is sufficient to build the dtb files:
make dtbs
If you want to build deb packages, use make deb-pkg.
.txt   0001-arm64-dts-rockchip-Fix-Bluetooth-on-the-RockPro64-bo.patch.txt (Size: 1.57 KB / Downloads: 463)
.txt   rk3399-rockpro64-v2.dtb.txt (Size: 78.48 KB / Downloads: 531)
.txt   rk3399-rockpro64.dtb.txt (Size: 78.48 KB / Downloads: 543)
Note that the edge kernel is now 5.19.16.
Convenience command:
sudo curl https://forum.pine64.org/attachment.php\?aid\=2677 -o /boot/dtb-5.19.16-rockchip64/rockchip/rk3399-rockpro64-v2.dtb
sudo curl https://forum.pine64.org/attachment.php\?aid\=2678 -o /boot/dtb-5.19.16-rockchip64/rockchip/rk3399-rockpro64.dtb
Starting from kernel 6.0 (today: 6.0.10), Bluetooth does not work for me. I needed to downgrade the kernel to version 5.19.16 for the Bluetooth to work again (regardless of this fix).
sudo apt install linux-dtb-edge-rockchip64=22.08.6 linux-image-edge-rockchip64=22.08.6
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 11 19,127 03-07-2026, 09:32 AM
  New OS for RockPro64 is here, TwisterOS Armbian jtremblant 92 160,225 08-17-2024, 02:32 PM
Last Post: taltamir
  OpenEuler OS on RockPro64 Yuriy Gavrilov 0 2,555 06-15-2024, 09:38 AM
Last Post: Yuriy Gavrilov
  yocto for RockPro64 Fide 1 4,234 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 8,940 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 38,880 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 120,288 08-11-2023, 11:13 AM
  How to enable CoreSight ETM trace on RockPro64 shpark 0 3,867 05-21-2023, 11:34 PM
Last Post: shpark
  Rockpro64 Dead on arrival? quixoticgeek 1 3,552 03-12-2023, 06:55 PM
Last Post: quixoticgeek
  RockPro64 boot questions misterc 3 5,726 01-13-2023, 06:21 PM
Last Post: misterc
