RP64 Won't Boot After Power Down
@belveder79, thanks for sharing your work
I've read it, still not sure what I need though.
I use this board with an Intel i350 nic + openwrt, and need to make the setup more reciliant to power outages. As described here https://forum.pine64.org/showthread.php?tid=14779
What hardware do I need to setup the watchdog? And was all the software (scripts etc) available at the github page? Read something about some ".. not open source the hardware files" in the end of the github page - but I don't understand what it means? Is this something I need to get the watchdog working?
Thanks, Erik
RP64 Won't Boot After Power Down - by ColPanic_ - 04-25-2021, 04:56 PM
RE: RP64 Won't Boot After Power Down - by LMM - 04-26-2021, 01:13 AM
RE: RP64 Won't Boot After Power Down - by LMM - 04-27-2021, 01:14 AM
RE: RP64 Won't Boot After Power Down - by LMM - 04-29-2021, 04:49 AM
RE: RP64 Won't Boot After Power Down - by gechu - 09-04-2021, 12:12 PM
RE: RP64 Won't Boot After Power Down - by tizbac - 04-08-2023, 06:56 AM
RE: RP64 Won't Boot After Power Down - by dkebler - 06-27-2023, 07:31 AM
  ROCKPro64 Battery Power Supply hoarfrosty 12 2,057 04-01-2024, 10:24 PM
Last Post: nano2
  No audio on HDMI after u-boot upgrade xlx 2 1,930 11-28-2023, 01:03 PM
  NAS Setup: Hdds PSU external power option Robotik 1 1,733 07-18-2022, 10:10 PM
Last Post: zer0sig
  NAS case HDD power cable failure (buck failure) ashleymills 1 1,917 04-01-2022, 11:25 AM
Last Post: ashleymills
  Power In Via DC Out actionhank 0 1,306 01-28-2022, 09:45 AM
Last Post: actionhank
  RockPro64 doesn't boot when PCIe to M.2 adapter is installed Cerberus 3 3,518 11-27-2021, 11:38 PM
Last Post: Cerberus
  RP64 TV box case with wifi Wizzard 2 3,302 03-10-2021, 12:23 AM
Last Post: Wizzard
  Carte PCIe bloquant le démarrage du Noyau / PCIe card blocking Kernel boot dml-pc 4 5,019 02-17-2021, 11:35 AM
Last Post: dml-pc
  How to add an external power button? foresto 6 9,125 02-05-2021, 10:38 PM
Last Post: foresto
  Won't boot with SATA card rjzak 4 5,770 01-09-2021, 05:56 PM
Last Post: kuleszdl
