NAS Setup: Hdds PSU external power option
Good day Everyone.
I decided to intall a 6 SATA Drive card and pack 6 2.5'' hdds in the NAS case the problem is that the Sata power dapter can only supply enought power for 2 drives.
I am looking for recomendations to supply power to the four remaining drives.
Until know I have been uing a USB to Sata converted connected to a fast phone charger. It works but from time to time a drive disappears, no doubt I am exceding the USB current settings. Hence I am looking for something that can supply more current to get my Hdds up and running.
I did used a 12V/5V 2A USB to IDE/SATA Power Supply Adapter For Hard Drive HDD CD-ROM Tool; of course if end up exploting after a few minute. RockPro survided
I attached a few pictures of the rack for refence. Plush blanket great for antistatic I know (Not!) YOLO
SATA PCIE hardware used :
BEYIMEI PCIE 4x SATA card 6 ports, 6 Gbit / s SATA 3.0, boot as System Diskette, Support 6 SATA 3.0 Devices, with 6 SATA cables and a 15pin SATA to 4SATA Power Distribution Cable(ASM1166)
Any suggestions?
that's pretty cool! if you were running SSDs, you might have enough power to split into multiple connectors in parallel, but 6 spinning disks? 2.5" draw less power but not that much less. Hmm..
it doesn't get happy
it doesn't get sad
it just runs programs
  ROCKPro64 Battery Power Supply hoarfrosty 12 2,049 04-01-2024, 10:24 PM
Last Post: nano2
  RP64 Won't Boot After Power Down ColPanic_ 10 7,814 06-27-2023, 07:31 AM
Last Post: dkebler
  External Touchscreen via DP-Alt Mode soloquintett 0 781 05-01-2023, 12:29 PM
Last Post: soloquintett
  NAS case HDD power cable failure (buck failure) ashleymills 1 1,915 04-01-2022, 11:25 AM
Last Post: ashleymills
  NAS setup: weird noise and reboot with 2 3.5" HDs Goffi 4 3,410 02-22-2022, 03:07 PM
Last Post: Goffi
  Power In Via DC Out actionhank 0 1,300 01-28-2022, 09:45 AM
Last Post: actionhank
  How to add an external power button? foresto 6 9,113 02-05-2021, 10:38 PM
Last Post: foresto
  NAS mods: external serial port and power button foresto 4 6,533 10-04-2020, 11:21 PM
Last Post: zer0sig
  Power Supply - Barrel length Wiing 2 3,609 09-20-2020, 12:38 AM
Last Post: Wiing
  Problems with maskrom OTG USB in Linux - Device not responding to setup address nutilius 0 1,773 08-31-2019, 11:40 AM
Last Post: nutilius
