RockPro64 doesn't boot when PCIe to M.2 adapter is installed
I see the green LED near the power plug and green LED on the adapter. After pressing the power button, I see some chromatic distortion on the display for about a second then nothing else. The white LED does not light up. After removing the adapter, I am able to boot up as expected. I am trying to boot from the SD card. My understanding is that the SD card would have a higher than NVMe for boot if I had flashed the SPI (to allow for NVMe booting), but I haven't flashed the SPI.
I removed my data SSD from my desktop and it boots as expected. The SSD that prevented booting is a SK Hynix PC300. I am not used to a computer being so picky. I've been using the SSD without problems for a year or two. Now I need to find a compatible SSD because I am using this one for my Ethereum blockchain.
(11-26-2021, 02:58 PM)Cerberus Wrote: I removed my data SSD from my desktop and it boots as expected. The SSD that prevented booting is a SK Hynix PC300. I am not used to a computer being so picky. I've been using the SSD without problems for a year or two. Now I need to find a compatible SSD because I am using this one for my Ethereum blockchain.
It is not picky, the ROCKPro 64 does not support M2 drives, only NVMe.
The PC300 is NVMe: https://www.amazon.com/SK-Hynix-256GB-So...B075QMZ1LC
  Powering two disks from RockPro64 some_pinephone_user 3 6,757 02-24-2026, 04:43 PM
Last Post: evilbunny
  TPM module for rockpro64 misha64 0 3,971 12-03-2024, 06:19 PM
Last Post: misha64
  ROCKPro64 Battery Power Supply hoarfrosty 12 15,259 04-01-2024, 10:24 PM
Last Post: nano2
  No audio on HDMI after u-boot upgrade xlx 2 6,891 11-28-2023, 01:03 PM
  Powering on the Rockpro64 JPT223 1 4,681 09-24-2023, 12:23 PM
Last Post: hoarfrosty
  RP64 Won't Boot After Power Down ColPanic_ 10 20,394 06-27-2023, 07:31 AM
Last Post: dkebler
  Compatible PCIe Sata Controller spacebricker 1 5,601 02-06-2023, 10:03 AM
Last Post: diizzy
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 50,635 12-18-2022, 06:25 PM
Last Post: heyghoge
  Using RPI hat on RockPro64? misterc 0 4,137 12-16-2022, 02:05 PM
Last Post: misterc
  PCIe bifurcation support (on RK3399) Arn 1 5,651 11-28-2022, 05:12 PM
