Compatible PCIe Sata Controller
Hello everyoneSmile
I was looking over the HCL on the pine64 wiki, searching for a good 4-port SATA controller. However, I could not find an exact match for what was specified. I only found this SATA controller.
This product does seem to be a close match, so I was wondering if this would work on a RockPro64 running Debian. Please let me know if you have any tips/advice regarding this.
Thank you!
You have two 6-port controllers listed here, https://wiki.freebsd.org/arm/RockChip#Te..._RockPro64 . I can't vouche for Debian compatibility though...
  Which SATA card should I use my NAS server RAID5 Louysa 3 866 09-24-2023, 04:40 AM
Last Post: JPT223
  SATA keeps crashing JPT223 1 533 09-21-2023, 10:52 PM
  SATA hotplug not working? JPT223 0 420 09-15-2023, 04:20 AM
Last Post: JPT223
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 25,617 12-18-2022, 06:25 PM
Last Post: heyghoge
  PCIe bifurcation support (on RK3399) Arn 1 1,312 11-28-2022, 05:12 PM
  Existings disks and using a StarTech SATA Controller jkugler 1 2,052 12-09-2021, 06:41 AM
Last Post: SVDSHRDJD
  RockPro64 doesn't boot when PCIe to M.2 adapter is installed Cerberus 3 3,469 11-27-2021, 11:38 PM
Last Post: Cerberus
  Rockpro64 Sata Card kills itself jerry110 33 44,038 10-20-2021, 04:36 AM
Last Post: fieni
  Right direction SATA card corax 2 2,941 09-15-2021, 12:46 PM
Last Post: corax
  Carte PCIe bloquant le démarrage du Noyau / PCIe card blocking Kernel boot dml-pc 4 4,957 02-17-2021, 11:35 AM
Last Post: dml-pc
