Troubleshooting ROCKPro64
(03-01-2021, 02:30 AM)alephnull Wrote: I recently bought a 4GB ROCKPro64 (including power supply) and am unable to make it boot. I have a serial adapter (running at 1500000bps) connected and have tried the following: There is no output following the output messages listed above and the board is not responsive to serial input.  I have tried 2 different SD cards (SanDisk Ultra 16GB A1) and in all cases, verified the data written to the card against the original image file.
Based on RockPro64 boot sequence, the "U-Boot TPL" lines suggest that the TPL is loading but the lack of a subsequent "U-Boot SPL" line suggests that the subsequent SPL loader is not starting.  The ayufan boot prompts are different but I'd expect something similar to my Rock64, which starts:
DDR version 1.13 20180428
In
SRX
LPDDR3
786MHz
I have tried raising a support ticket but, after more than a month, that has gone nowhere - the only suggestions have been to run a memory test, without actually providing any suggestion as to where I might find a memory test that doesn't require a fully functional U-Boot.  Can anyone here suggest additional troubleshooting steps I can perform?
Hi, you eventually could try to erase the spi and flash it again (https://github.com/sigmaris/u-boot/wiki/...oot-to-SPI)
Troubleshooting ROCKPro64 - by alephnull - 03-01-2021, 02:30 AM
RE: Troubleshooting ROCKPro64 - by LMM - 03-01-2021, 03:55 PM
RE: Troubleshooting ROCKPro64 - by LMM - 03-02-2021, 07:17 AM
RE: Troubleshooting ROCKPro64 - by alephnull - 03-04-2021, 03:58 AM
  Installing Wifi drive for the RockPro64 John45595 0 344 02-10-2024, 11:32 PM
Last Post: John45595
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 815 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 710 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 4,358 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 928 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 1,372 04-06-2023, 02:46 PM
  Cant get rockpro64 working brasilikum 3 1,888 03-19-2023, 06:22 AM
Last Post: runyor
  RockPro64 Stopped working WarpLover 5 2,757 02-06-2023, 10:10 AM
Last Post: diizzy
Lightbulb ROCKPro64 + SSD case model for 3D print Spater 0 1,041 01-27-2023, 07:43 PM
Last Post: Spater
  RockPro64 and Neon rapier1 2 1,855 10-21-2022, 07:44 AM
Last Post: rapier1
