KDE Keyboard -- CTRL / ALT keys in Konsole
(02-21-2021, 11:09 PM)MtnSk8 Wrote: I got spoiled using Mobian with the terminal keyboard always available. Big Grin
Thanks for the reply.
Smile
Cheers!
Actually, correct bug report is here (the QMLKonsole git):
https://invent.kde.org/plasma-mobile/qml...-/issues/1
So patch above is not to the original project git so it will never come.
It would be good for someone with an account with kde.org to mention the above proposed code.
Do the Manjaro guys check this forum or stick to their own?
I just figured out how to modify the Mobian squeekboard keyboard, wondering about the Plasma Mobile one.
Mobian one doesn't seem to cater for Caps Lock, though, so I created a Capslock key that takes you to an uppercase keyboard.
I must say I'm no fan of fragmentation, so Pine64 choosing a desktop environment should be a good thing.
Shame there isn't a desktop environment subsection for Manjaro on Pinephone (same about ugly Manjaro forum).
I switched to terminator, which I use on my laptop and had installed on Mobian, too.
I use to run a script via a desktop launcher.
Interestingly the terminator keyboard does NOT have the top scroll line that qmlKonsole has, so what I really want to know is how to modify the original virtual keyboard to add relevant navigation keys etc. Pretty basic for a touchscreen device.....
Does anybody know?
RE: KDE Keyboard -- CTRL / ALT keys in Konsole - by dcinoz - 02-21-2021, 11:57 PM
  No keyboard in Signal Desktop Kimberley van Buyten 4 2,473 10-16-2022, 10:25 AM
Last Post: Eugo
  Where do the keyboard layouts go? Eugo 1 1,133 08-31-2022, 11:03 AM
Last Post: Eugo
Sad Latest Manjaro breaks Keyboard Case (Again)? hollerpots 4 2,871 06-17-2022, 07:48 AM
Last Post: hollerpots
  Vivaldi Browser doesn't start keyboard for text entry tckosvic 1 2,052 05-24-2022, 11:32 PM
  How to convert your pinephone to a palmtop now that you have the clamshell keyboard rotwang 3 3,141 05-09-2022, 08:29 AM
Last Post: ragreenburg
  Keyboard case stopped working on pacman update rotwang 5 3,251 05-07-2022, 09:17 PM
Last Post: rotwang
  Ctrl-O on virtual keyboard not working in nano PJK2012 3 3,244 11-11-2021, 08:47 PM
Last Post: PJK2012
  open on-screen keyboard at will yogo1212 2 2,950 06-12-2021, 06:15 PM
Last Post: ryo
  How to close app when using dock/mouse/keyboard/ext display? alx27 0 1,274 05-27-2021, 06:09 AM
Last Post: alx27
  How to disable vibration feedback on the touch keyboard? punchy88 0 1,751 11-26-2020, 02:15 PM
Last Post: punchy88
