Vivaldi Browser doesn't start keyboard for text entry
Installed vivaldi browser (that I like alot) through Discover onto pinephone.  Vivaldi starts fine but does not start keyboard to enter text upon selection of a text box.
Did several reboots with no change.
Vivaldi works well on my android samsung galaxy phone.  I also use vivaldi as default browser on my linux pc.
Anyone seen same thing? Anyone found a solution?
I will post this on vivaldi forum also.
thanks,    tom kosvic
(11-14-2021, 10:31 AM)tckosvic Wrote: Installed vivaldi browser (that I like alot) through Discover onto pinephone.  Vivaldi starts fine but does not start keyboard to enter text upon selection of a text box.
thanks,    tom kosvic
I have seen this under mobian where the work around is to place the cursor in the text field and hit the keyboard icon at the bottom right of the screen.This brings up the on screen keyboard. I now use my PinePhone with the keyboard which makes it easier.
Occasionally Vivaldi starts up in a way that it is not possible to type anything into the address bar. In these situations I just restart Vivaldi and it works fine again.
The fact that you can scale the Vivaldi UI is very useful on "non-standard" screen usage. Such as the PinePhone or on a media PC where you sit a couple of metres from the screen. That Vivaldi will not implement the FLoC code makes it interesting for me as well.
  No keyboard in Signal Desktop Kimberley van Buyten 4 2,383 10-16-2022, 10:25 AM
Last Post: Eugo
  Where do the keyboard layouts go? Eugo 1 1,102 08-31-2022, 11:03 AM
Last Post: Eugo
Sad Latest Manjaro breaks Keyboard Case (Again)? hollerpots 4 2,775 06-17-2022, 07:48 AM
Last Post: hollerpots
  How to convert your pinephone to a palmtop now that you have the clamshell keyboard rotwang 3 3,071 05-09-2022, 08:29 AM
Last Post: ragreenburg
  Keyboard case stopped working on pacman update rotwang 5 3,167 05-07-2022, 09:17 PM
Last Post: rotwang
  auto start waydroid in plasma mobile? Uturn 2 2,441 04-19-2022, 03:47 AM
Last Post: dorthatapia
  How to paste text in Plasma Mobile? jojuma 5 3,891 11-13-2021, 11:04 AM
Last Post: acrux
  Ctrl-O on virtual keyboard not working in nano PJK2012 3 3,174 11-11-2021, 08:47 PM
Last Post: PJK2012
  KDE Keyboard -- CTRL / ALT keys in Konsole MtnSk8 4 3,745 08-29-2021, 03:28 AM
Last Post: YellowApple
Question Infinite loop: passcode entry -> lock-screen, repeat danimations 3 3,084 07-12-2021, 08:21 PM
Last Post: danimations
