Use SD to install new OS over pinebook debian
(07-10-2021, 01:11 AM)osmana Wrote:
(02-10-2021, 08:45 PM)Rudy558 Wrote: Hello,
Firstly, sorry if this isn't where I should post this, I'm a first time poster. Just let me know and I'll move it.
I''m trying to use an SD of the Debian Desktop Community Build Image [microSD to eMMC] (which is the same OS as my pinebook pro laptop) to install a new OS over the OS on my pinebook. I have been able to access gb whatsapp live boot on the SD card, but don't know where to go from here. I have installed other linux distros over other OSs in the past using bootable USBs before, but the procedure for this seems to be different. None of the normal prompts are appearing.
So far I've updated and upgraded. At this point, I'm not sure whether the changes I've made are applying only to the SD card or to the actual hard drive, I suspect just the SD card.
Any help with installing an OS to the actual laptop is appreciated!
Do I need a a separate device to make it work? what do I do? I have installed debian desktop for pbp onto an sd card but it doesn't have any install options.
I think you don't need to implement this on a separate device if you already having this issue, but you can change your sd card if you were unable to solve the issue and install debian.
RE: Use SD to install new OS over pinebook debian - by jackwilson - 09-25-2022, 01:19 AM
  Pinebook Pro Initial Impressions kunger 443 590,781 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,318 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 406 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 310 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 295 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 231 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 682 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 762 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,644 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,252 12-15-2023, 02:11 PM
