Manjaro Dim Display (Brightness 40%) After Every System Reboot
[Image: b6012d21108bcad487dc265542ab4ab1-full.png]
These tabs (On AC Power/On Batter) set the brightness at startup. Cheers!
edit: Also if you uncheck the top box on both tabs the last brightness value will be set at startup.
RE: Manjaro Dim Display (Brightness 40%) After Every System Reboot - by MtnSk8 - 02-15-2021, 07:04 PM
  Manjaro Sway Theme Broken Eighty8 1 290 03-08-2024, 08:41 AM
Exclamation 'failed to open panfrost' after system update using archarm Puckla 1 334 03-01-2024, 06:46 PM
Last Post: Puckla
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,765 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 336 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,159 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,237 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 415 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 906 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Fedora 36 -> 37 upgrade kills system tydeman 0 455 10-28-2023, 09:53 AM
Last Post: tydeman
  Sleep and external display - Are there any options? chris88233 7 1,737 09-04-2023, 09:03 PM
