PineBook Pro Bootcrash on Manjaro
Thank you for good ideas. I have tried with Etching SD card, but it was impossible to install to eMMC with manjaro 20.12, there is only one version https://osdn.net/projects/manjaro-arm/st...de-plasma/ with installing to eMMC.
To correctly boot from SD, first need to power off before inserting to pbp. Then after the circle with spin for about 15 seconds, press ESC.
The installation process is simple and self explanatory:
information appears that installing to eMMC will delete all data. Then you are asked to choose eMMC device: chose mmcblk2. Then flashing will be completed in about 4 minutes.
Why boot crashed after update? I do not now. After re flashing eMMC pbp boots correctly. The only issue now is that the updates don't work.
PineBook Pro Bootcrash on Manjaro - by PineHead7 - 12-11-2020, 04:41 PM
RE: PineBook Pro Bootcrash on Manjaro - by KC9UDX - 12-11-2020, 10:48 PM
RE: PineBook Pro Bootcrash on Manjaro - by jiyong - 12-12-2020, 03:42 PM
RE: PineBook Pro Bootcrash on Manjaro - by KC9UDX - 12-12-2020, 06:23 PM
RE: PineBook Pro Bootcrash on Manjaro - by KC9UDX - 12-14-2020, 03:06 AM
RE: PineBook Pro Bootcrash on Manjaro - by PineHead7 - 12-20-2020, 05:25 AM
  Debian on Pinebook Pro u974615 7 1,198 03-31-2024, 10:11 AM
Last Post: u974615
  Manjaro Sway Theme Broken Eighty8 1 305 03-08-2024, 08:41 AM
  Pinebook Pro upgrading from the factory image yamsoup 12 1,689 02-22-2024, 04:02 PM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,783 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 356 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,197 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,279 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 89,618 12-08-2023, 11:25 PM
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 427 12-07-2023, 03:11 PM
  Boot Order in Pinebook Pro food 8 1,298 11-23-2023, 07:37 AM
