Bricked Pinetab?
(11-27-2020, 10:14 AM)my3ke Wrote: I updated my SD card via apt and all was well.  It's running Mobian and the emmc is UB Touch.  Rebooted the critter and all is dark.  I can hear some noises in the tab if I put my ear to it, and can power it down so it is quiet, but when I power it up, no display and the keyboard doesn't light up anymore.
So I removed my SD card to use Touch and it also doesn't respond!  That doesn't make sense.
So is there a procedure to restore the emmc to it's original settings, or at least to get Mobian working on the SD card again so I can use it once again?
thanks,
My3ke
It sounds as if you need to completely power it off. Remove the SD card - See if it reboots
If that has not helped and you can still boot off neither you may need to reflash your device as I doubt it is broken - I have had the same issue (sadly far too often)
Download Jumpdrive here:
https://github.com/dreemurrs-embedded/Ju...es/tag/0.6
Flash it using the instructions here on to a small sdcard: https://github.com/dreemurrs-embedded/Ju...stallation
When you then flash the sd card in your pinetab it will be visible when connected to a pc (and importantly flashable!)
Download a newer Ubuntu Touch pinetab image (the wiki link is old - I will try to update it today) from here :
https://ci.ubports.com/job/rootfs/job/ro...tab.img.xz
(The old links look deprecated https://ci.ubports.com/job/rootfs/job/rootfs-pinetab/)
If you use Ubuntu you can reflash the device quite easily with the Disks programme to restore the Ubuntu Pinetab image directly onto your emmc.
That will at least get your pinetab back up as you had it - like new!
1 Now with Pinephone Pro (used to have Pinephone and Pinetab) cooking on Mobian - Seasoned Ubuntu user since 2007
2 Known to break things - often
3 Sometimes known to fix things then see 2 above
Bricked Pinetab? - by my3ke - 11-27-2020, 10:14 AM
RE: Bricked Pinetab? - by rocket2nfinity - 11-27-2020, 04:03 PM
RE: Bricked Pinetab? - by fritz - 11-27-2020, 10:05 PM
RE: Bricked Pinetab? - by rocket2nfinity - 11-28-2020, 04:04 AM
RE: Bricked Pinetab? - by fritz - 11-28-2020, 07:23 AM
RE: Bricked Pinetab? - by my3ke - 11-28-2020, 10:36 AM
RE: Bricked Pinetab? - by andybleaden@gmail.com - 11-30-2020, 05:31 AM
  Not able to power on PineTab anymore zkajdan 3 455 12-26-2023, 04:38 PM
Last Post: FortunateFowl
Question Will Pinetab 2 spare parts be available? vatin 6 1,575 12-09-2023, 01:31 AM
  ?brighter screen replacement for pinetab (>1600 nits) dynobang 0 542 09-28-2023, 01:06 PM
Last Post: dynobang
  [Tutorial] How to overclock Pinetab 2 Darth-Apple 0 818 09-25-2023, 08:45 AM
Last Post: Darth-Apple
  External Reset button on PineTab V? michaelengel 0 536 09-18-2023, 06:31 AM
Last Post: michaelengel
  Pinetab 2 screen no longer coming on Fibonacci 9 2,990 06-30-2023, 08:26 AM
Last Post: Purple_Illusion
  Pinetab completely bricked Saksmito 8 2,610 06-10-2023, 04:23 PM
Last Post: fxc
  What RISC-V chip will the PineTab-V use? msm 2 1,662 04-05-2023, 06:58 PM
Last Post: msm
Big Grin Howto: Pinetab Screen Replacements (+ Pictures) RTP 5 6,432 02-10-2022, 08:31 PM
Last Post: barray
  Offer: PineTab with keyboard firefox-58 3 4,700 09-27-2021, 12:36 PM
Last Post: stmguard
