Pinebook Pro PCIe init issue
(11-03-2020, 05:34 PM)R32Fanboy Wrote: A few days ago I got the NVME adapter for my pbp. I bought an Intel 660p SSD for it, since it was marked as supported on the wiki. After install, it didn't show up in lspci or lsblk.
the output of dmesg | grep pci returns these errors:
[    2.953763] rockchip-pcie f8000000.pcie: no vpcie12v regulator found
[    3.112162] ehci-pci: EHCI PCI platform driver
[    3.174161] ohci-pci: OHCI PCI platform driver
[    3.733470] rockchip-pcie f8000000.pcie: no vpcie12v regulator found
[    4.318696] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[    4.320361] rockchip-pcie: probe of f8000000.pcie failed with error -110
I tried updating U-boot on the SPI chip as well as on the SD card, I've tried Debian, Manjaro, Fedora, it's all the same.
I then turned to a friend who also owns a PBP and had them run lspci and dmesg | grep pci and their own pbp returned the same error (their pbp is a first-run preorder and I bought mine a year later.). Is this a hardware issue or is there something I'm missing in the NVME installation that allows this board to initialize it's PCIe properly?
I have this issue too, see https://forum.pine64.org/showthread.php?tid=10118 and even today, after flashing multiple spins of uboot to emmc, sd and SPI along with 2 new nvme adapter boards from Pine store, get the same pci related errors as above. (BTW, this is with first batch PBP & supported NMVe drive per wiki).
It might be the ribbon cable conductivity on your adapter which you could verify with a multimeter as per this thread: https://forum.pine64.org/showthread.php?...904&page=2 and if so, try the adapter from ameridroid store - definitely not from Pine store.
Won't mention the response received from Pinestore after the second adapter did not work for me and I got redirected to their IRC (but someone has already noted "worst support ever") so check the cable continuity and maybe get a new one from ameridroid?
Hope that helps and sad to see this issue is still being reported on something that has been out for nearly a year.
Pinebook Pro PCIe init issue - by R32Fanboy - 11-03-2020, 05:34 PM
RE: Pinebook Pro PCIe init issue - by as400 - 11-04-2020, 12:58 AM
RE: Pinebook Pro PCIe init issue - by vssz - 11-04-2020, 07:10 AM
RE: Pinebook Pro PCIe init issue - by R32Fanboy - 11-04-2020, 04:36 PM
RE: Pinebook Pro PCIe init issue - by vssz - 11-05-2020, 09:59 AM
  Pinebook Pro Initial Impressions kunger 443 587,840 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,284 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 395 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 297 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 285 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 219 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 664 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 735 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,599 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,223 12-15-2023, 02:11 PM
