10-27-2020, 05:35 PM
(This post was last modified: 11-02-2020, 06:19 PM by AronShap.
Edit Reason: Added that this is for Manjaro OS to clear up any confusion with another OS.
(10-23-2020, 11:16 AM)11Eleven Wrote: Greetings,This is for Manjaro OS
Do any of you use VPN's on your pinebook pro? I tried installing PrivateInternetAccess on mine, but it doesn't want to run. I was wondering if anybody here had any success with it, or could point me to a suitable alternative. Also, how would I go about uninstalling it, I'm still presently a noob...
Thanks!
You can configure PIA VPN through System settings GUI > Click connections under Network > Click + (add new connection) > select OPENVPN > in VPN (openvpn) tab enter your gateway i.e.
"us-atlanta.privacy.network" , change connection type to password, select your CA Certificate (browse for location of your ca.rsa.2048 cert. Click on advanced > General tab check box use custom gateway port enter 1198 check box use LZO compression (change to adaptive) > Click security tab change cipher to AES-128-CBC change HMAC Authentication to SHA-1.
Connect to your network then connect to the VPN (picture of a shield) from the toolbar.
Config files download OPENVPN CONFIGURATION FILES (DEFAULT)
https://www.privateinternetaccess.com/he...ovpn-files
