Pinebook Pro Won't Accept Charge
Online will usually be a bit more money, look for the word charging, so maybe
the wires are a bit thicker,, a standard cable, "C" at one end, "A" at the other
The C end can be plugged in 2 different ways, label up or label down
Sometimes it makes a difference, sometimes not. If it is working, the red led will light
You will have to find (or buy) your most powerful charger, 2.4A is usual maximum
Obviously, for a test, OR overnight, you can use one with less amperage, try for 1A minimum
A pc, the usb3 port supplies 900 mA, usb2 gives 500mA
BTW, the pbp usbC port is NOT smart, so don't need to get fancy cable or PD/QC charger
Do try to get a cable that is thick, there are 10 wires in it after all
Pinebook Pro Won't Accept Charge - by rempfer - 10-14-2020, 09:17 PM
RE: Pinebook Pro Won't Accept Charge - by wdt - 10-14-2020, 10:26 PM
RE: Pinebook Pro Won't Accept Charge - by rempfer - 10-15-2020, 12:46 AM
RE: Pinebook Pro Won't Accept Charge - by MtnSk8 - 10-15-2020, 07:55 AM
RE: Pinebook Pro Won't Accept Charge - by wdt - 10-15-2020, 07:59 AM
RE: Pinebook Pro Won't Accept Charge - by rempfer - 10-15-2020, 10:17 PM
  Pinebook Pro Initial Impressions kunger 443 594,188 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,343 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 427 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 324 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 310 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 245 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 702 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 785 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,716 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,306 12-15-2023, 02:11 PM
