Happy eMMC and SDcard OS usage for Pinebook Pro Newbies...
#21
(10-09-2020, 01:13 PM)wdt Wrote: OK, lsblk 1st,, boot0 and boot1 are on emmc, I will use terms /dev/SD and /dev/emmc,,
replace SD and emmc with right mmcblkX
Then, sudo gdisk /dev/SD,,, the screen that comes up will have this section
Partition table scan:
  MBR: MBR only
  BSD: not present
  APM: not present
  GPT: not present
So you can tell the partitioning style of the disk, Ayufan often uses GPT
If it is mbr, you save 1 sector, if gpt save 34 sectors,,, (dd default bs is 512 Bytes, 1 sector)
(GPT has protective mbr, 1 sector, GPT boot code, 1 sector, partition table, 32 sectors,,4/sector,128 partitions)
make a directory to work in, empty
cd ; mkdir uboot-sav ; cd uboot-sav
save SD mbr
dd if=/dev/SD of=SD.ubuntu.mbr count=(either 1 OR 34)
save ubuntu uboot(optional), good practice to always be able to go back
dd if=/dev/SD of=ubuntu.uboot.16M bs=1M count=16
Transfer 1st-16M emmc->SD
dd if=/dev/emmc of=/dev/SD bs=1M count=16
restore mbr
dd if=SD.ubuntu.mbr of=/dev/SD  (count not necessary, will stop at end of file)
Also a good practice to give self documenting names, very helpful a month later
This assumes manjaro on emmc,, ayufan ubuntu on SD,, ubuntu boots OK
Doesn't matter where you boot from, but if SD card is in, will boot ubuntu
Then test, remove/disable emmc, can SD boot OK?  If so, transfer ubuntu to emmc,,
with rsync (already in forum OR on other computer OR do an install from image,, BUT
BEFORE rebooting transfer manjaro uboot to emmc (saving emmc mbr 1st, and restoring last)
Thank you so much. Yep the image had GPT partition. Followed your steps and it worked. I booted into Ubuntu 20.04. However I updated Ubuntu to 20.10 and it boots but fails and tells me to enter maintenance. I may have to attempt the steps again for the new update.
RE: Happy eMMC and SDcard OS usage for Pinebook Pro Newbies... - by Mangled - 10-10-2020, 09:34 PM
Booting from SD - by rkharris - 11-28-2020, 05:46 PM
  Pinebook Pro Initial Impressions kunger 443 593,784 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,338 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 424 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 321 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 306 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 242 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 698 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 781 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,696 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,291 12-15-2023, 02:11 PM
