openwrt for the rock64
#25
Hey, sorry about the long hiatus, I've just been able to get around to working on this again.
I've got OpenWRT running on the Rock64.
My branch is at https://github.com/CanadianBaconBoi/openwrt/tree/rock64. These changes are from "lucize", I just ported them to a newer openwrt version. Original source here.
Issue is that you have to compile all of the packages you need at build time because it's running kernel version 5.10.103
In light of this I have compiled all packages against kernel 5.10.103 and created a repo at openwrt.cdnbcn.net.
These packages will be linked so you can host your own repo too Big Grin.
You will have to modify the file "/etc/opkg/distfeeds.conf" in openwrt and swap them out for my or your repo.
Attached is also a build config so you can recreate the SD card image with the source from my repo without having to configure the image yourself.
Just copy the file to your <buildroot> and rename it to ".config".
All packages are confirmed working with the attached image. I hope I can help some people out with this Big Grin.
Source Repo: https://github.com/CanadianBaconBoi/openwrt/tree/rock64
SD Card Image: https://drive.google.com/file/d/10hqytuL...sp=sharing
Build Config: https://drive.google.com/file/d/1BhI6juX...sp=sharing
Custom Repo: http://openwrt.cdnbcn.net
Repo Packages: https://drive.google.com/file/d/1tJC3kNy...sp=sharing
openwrt for the rock64 - by wilsonYan - 08-11-2020, 12:13 AM
RE: openwrt for the rock64 - by tophneal - 08-11-2020, 09:49 AM
RE: openwrt for the rock64 - by yura407 - 11-29-2020, 11:30 PM
RE: openwrt for the rock64 - by chainu127 - 01-16-2021, 11:16 PM
RE: openwrt for the rock64 - by chainu127 - 02-01-2021, 09:23 PM
RE: openwrt for the rock64 - by chainu127 - 02-08-2021, 10:08 PM
RE: openwrt for the rock64 - by wilsonYan - 04-05-2021, 10:17 PM
RE: openwrt for the rock64 - by wilsonYan - 04-23-2021, 01:37 AM
RE: openwrt for the rock64 - by gechu - 05-12-2021, 12:10 PM
RE: openwrt for the rock64 - by helpmerock - 05-14-2021, 11:16 PM
RE: openwrt for the rock64 - by gechu - 05-15-2021, 02:20 PM
RE: openwrt for the rock64 - by helpmerock - 05-16-2021, 10:26 AM
RE: openwrt for the rock64 - by helpmerock - 05-21-2021, 10:14 AM
RE: openwrt for the rock64 - by stamasd - 05-22-2021, 11:16 AM
RE: openwrt for the rock64 - by stamasd - 05-23-2021, 07:53 AM
RE: openwrt for the rock64 - by wilsonYan - 06-28-2021, 09:50 PM
RE: openwrt for the rock64 - by wilsonYan - 09-22-2021, 01:33 AM
RE: openwrt for the rock64 - by wilsonYan - 09-22-2021, 06:38 PM
RE: openwrt for the rock64 - by helpmerock - 11-26-2021, 08:01 PM
RE: openwrt for the rock64 - by CanadianBacon - 12-20-2021, 11:46 AM
RE: openwrt for the rock64 - by helpmerock - 12-21-2021, 08:54 AM
RE: openwrt for the rock64 - by helpmerock - 12-21-2021, 09:56 AM
RE: openwrt for the rock64 - by c012 - 01-16-2022, 10:30 PM
RE: openwrt for the rock64 - by stamasd - 02-12-2022, 08:52 AM
RE: openwrt for the rock64 - by CanadianBacon - 03-09-2022, 11:37 PM
RE: openwrt for the rock64 - by CanadianBacon - 03-10-2022, 03:23 PM
RE: openwrt for the rock64 - by CanadianBacon - 03-12-2022, 06:59 PM
RE: openwrt for the rock64 - by helpmerock - 03-13-2022, 04:24 PM
RE: openwrt for the rock64 - by CanadianBacon - 03-13-2022, 06:42 PM
RE: openwrt for the rock64 - by CanadianBacon - 03-13-2022, 10:25 PM
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 158 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,377 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 344 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 629 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 621 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,483 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,967 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 601 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 657 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,633 12-07-2022, 08:22 PM
Last Post: luminosity7
