slarm64 (unofficial slackware) Pinebook Pro RK3399 (aarch64)
#24
"once again, there is a script that transfers to eMMC"
I used that script the first time, and installed to eMMC.
Then I messed around with getting luks+lvm working on microsd.
Once successful, after booting from microsd, made the luks+lvm work on eMMC.
I didn't use your script for installing to eMMC that time, because I didn't think it would know about luks+lvm.
That's about when I noticed not all the hardware being detected.
Once I found your blobs, all is well.
When I did have that resume=LABEL=blackholezswap in my kernel append line, it froze looking for some kind of resume image, so I removed that entry from the line... however, I noticed at kernel.org's list of kernel command-line parameters, a resumewait parameter, that I'll try and see if that helps it find the swap partition... Suspend to Ram, or having laptop go to sleep when lid is closed, is final hurdle.
RE: slarm64 (unofficial slackware) Pinebook Pro RK3399 (aarch64) - by globaltree - 12-04-2020, 05:51 PM
  Debian on Pinebook Pro u974615 7 1,419 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,881 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,271 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,368 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 90,278 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,407 11-23-2023, 07:37 AM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,558 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,587 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Install deepin OS on pinebook pro wangyukunshan 4 1,694 08-07-2023, 01:12 PM
Last Post: myself600
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 698 07-13-2023, 05:21 PM
Last Post: owaspfap
