slarm64 (unofficial slackware) Pinebook Pro RK3399 (aarch64)
(12-03-2020, 09:18 AM)mara Wrote: could you please provide the dmesg output.5
Quote:Hi.  I rebuilt 5.9.9 again, becaue I was trying 10.0.0-rc5 from tsys when you replied... but got the same results from that source too (doesn't find internal wlan0 or bluetooth).  So I think it's weird.  Because when I boot from the microsd with the slarm image, it finds internal lan and bluetooth. The microsd has the image found at linuxquestions.
I used the 5.9.9 source that was on that image, and the config from /proc/config.gz, when booted from that image.
The only change I made to the source was changing DM_CRYPT from M to Y, I enabled SMACK in security, and I appended -sib1 to help identify my experimental build.
When I grep hci, it complains about missing firmware patch.  Here's dmesg
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.9.9-sib1 (root@pinebook-pro) (gcc (GCC) 9.3.0, GNU ld version 2.33.1-slack15) #1 SMP Thu Dec 3 22:28:32 PST 2020
[    0.000000] Machine model: Pine64 Pinebook Pro
[    0.000000] earlycon: uart8250 at MMIO 0x00000000ff1a0000 (options '')
[    0.000000] printk: bootconsole [uart8250] enabled
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 64 MiB at 0x00000000f0000000
[    0.000000] Zone ranges:
[    0.000000]  DMA      [mem 0x0000000000200000-0x000000003fffffff]
[    0.000000]  DMA32    [mem 0x0000000040000000-0x00000000f7ffffff]
[    0.000000]  Normal  empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]  node  0: [mem 0x0000000000200000-0x00000000f7ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000000f7ffffff]
[    0.000000] On node 0 totalpages: 1015296
[    0.000000]  DMA zone: 4088 pages used for memmap
[    0.000000]  DMA zone: 0 pages reserved
[    0.000000]  DMA zone: 261632 pages, LIFO batch:63
[    0.000000]  DMA32 zone: 11776 pages used for memmap
[    0.000000]  DMA32 zone: 753664 pages, LIFO batch:63
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 34 pages/cpu s101656 r8192 d29416 u139264
[    0.000000] pcpu-alloc: s101656 r8192 d29416 u139264 alloc=34*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 999432
[    0.000000] Kernel command line: earlycon=uart8250,mmio,0xff1a0000 console=ttyS2,1500000n8 root=LABEL=blackholezroot rootwait rootfstype=ext4 rw init=/sbin/init panic=10 coherent_pool=1M ethaddr= eth1addr= serial=cfecc1fa7d8b2007 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 zswap.enabled=1 video=HDMI-A-1:1920x1080@60 video=eDP-1:1920x1080@60 loglevel=3 vga=current
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB)
[    0.000000] Memory: 3804236K/4061184K available (14528K kernel code, 828K rwdata, 5788K rodata, 2944K init, 8487K bss, 191412K reserved, 65536K cma-reserved)
[    0.000000] random: get_random_u64 called from cache_random_seq_create+0x80/0x150 with crng_init=0
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6.
[    0.000000] Trampoline variant of Tasks RCU enabled.
[    0.000000] Rude variant of Tasks RCU enabled.
[    0.000000] Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 256 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fef00000
[    0.000000] ITS [mem 0xfee20000-0xfee3ffff]
[    0.000000] ITS@0x00000000fee20000: allocated 65536 Devices @f6c80000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x00000000f6c50000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000000f6c60000
[    0.000000] GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
[    0.000000] GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.001364] Console: colour dummy device 80x25
[    0.001419] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.001431] pid_max: default: 32768 minimum: 301
[    0.001628] LSM: Security Framework initializing
[    0.001728] Yama: becoming mindful.
[    0.001783] Smack:  Initializing.
[    0.001786] Smack:  IPv6 port labeling enabled.
[    0.001876] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.001902] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.004335] rcu: Hierarchical SRCU implementation.
[    0.004650] Platform MSI: interrupt-controller@fee20000 domain created
[    0.005157] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.006087] EFI services will not be available.
[    0.006665] smp: Bringing up secondary CPUs ...
[    0.007282] Detected VIPT I-cache on CPU1
[    0.007323] GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000
[    0.007339] GICv3: CPU1: using allocated LPI pending table @0x00000000f6c70000
[    0.007393] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.008129] Detected VIPT I-cache on CPU2
[    0.008159] GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000
[    0.008173] GICv3: CPU2: using allocated LPI pending table @0x00000000f6d00000
[    0.008203] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.008874] Detected VIPT I-cache on CPU3
[    0.008903] GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000
[    0.008916] GICv3: CPU3: using allocated LPI pending table @0x00000000f6d10000
[    0.008946] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.009668] CPU features: detected: Branch predictor hardening
[    0.009679] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.009686] Detected PIPT I-cache on CPU4
[    0.009718] GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000
[    0.009731] GICv3: CPU4: using allocated LPI pending table @0x00000000f6d20000
[    0.009765] CPU4: Booted secondary processor 0x0000000100 [0x410fd082]
[    0.010475] Detected PIPT I-cache on CPU5
[    0.010502] GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000
[    0.010514] GICv3: CPU5: using allocated LPI pending table @0x00000000f6d30000
[    0.010541] CPU5: Booted secondary processor 0x0000000101 [0x410fd082]
[    0.010647] smp: Brought up 1 node, 6 CPUs
[    0.010653] SMP: Total of 6 processors activated.
[    0.010660] CPU features: detected: 32-bit EL0 Support
[    0.010667] CPU features: detected: CRC32 instructions
[    0.010674] CPU features: detected: 32-bit EL1 Support
[    0.045801] CPU: All CPU(s) started at EL2
[    0.045877] alternatives: patching kernel code
[    0.049387] devtmpfs: initialized
[    0.063526] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.063544] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.065162] pinctrl core: initialized pinctrl subsystem
[    0.065692] DMI not present or invalid.
[    0.066190] NET: Registered protocol family 16
[    0.068864] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.069152] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.069553] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.069677] audit: initializing netlink subsys (disabled)
[    0.069895] audit: type=2000 audit(0.070:1): state=initialized audit_enabled=0 res=1
[    0.070922] thermal_sys: Registered thermal governor 'fair_share'
[    0.070925] thermal_sys: Registered thermal governor 'bang_bang'
[    0.070930] thermal_sys: Registered thermal governor 'step_wise'
[    0.070934] thermal_sys: Registered thermal governor 'user_space'
[    0.071359] cpuidle: using governor ladder
[    0.071394] cpuidle: using governor menu
[    0.071954] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.072116] ASID allocator initialised with 65536 entries
[    0.072262] Serial: AMBA PL011 UART driver
[    0.126416] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.126424] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.126430] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.126436] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.139418] cryptd: max_cpu_qlen set to 1000
[    0.166584] ACPI: Interpreter disabled.
[    0.167671] vcc_12v: supplied by vcc_sysin
[    0.168053] vcc3v3_sys: supplied by vcc_sysin
[    0.168524] vcc5v0_usb: supplied by vcc_sysin
[    0.168911] vcc_0v9: supplied by vcc3v3_sys
[    0.169237] vcca1v8_s3: supplied by vcc3v3_sys
[    0.169645] vcc3v0_sd: supplied by vcc3v3_sys
[    0.170113] vcc3v3_panel: supplied by vcc3v3_sys
[    0.290392] vcc3v3_ssd: supplied by vcc3v3_sys
[    0.290804] vcc5v0_otg: supplied by vcc5v0_usb
[    0.291237] vbus_5vout: supplied by vcc5v0_usb
[    0.292266] iommu: Default domain type: Translated
[    0.294903] vgaarb: loaded
[    0.295670] SCSI subsystem initialized
[    0.295867] libata version 3.00 loaded.
[    0.296069] usbcore: registered new interface driver usbfs
[    0.296106] usbcore: registered new interface driver hub
[    0.296183] usbcore: registered new device driver usb
[    0.296737] mc: Linux media interface: v0.10
[    0.296761] videodev: Linux video capture interface: v2.00
[    0.296794] pps_core: LinuxPPS API ver. 1 registered
[    0.296798] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.296810] PTP clock support registered
[    0.297054] EDAC MC: Ver: 3.0.0
[    0.298043] Advanced Linux Sound Architecture Driver Initialized.
[    0.298504] NetLabel: Initializing
[    0.298509] NetLabel:  domain hash size = 128
[    0.298513] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.298564] NetLabel:  unlabeled traffic allowed by default
[    0.299222] clocksource: Switched to clocksource arch_sys_counter
[    0.299440] VFS: Disk quotas dquot_6.6.0
[    0.299499] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.299969] pnp: PnP ACPI: disabled
[    0.307600] NET: Registered protocol family 2
[    0.308250] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.308331] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.308675] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[    0.309374] TCP: Hash tables configured (established 32768 bind 32768)
[    0.309517] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.309651] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.309984] NET: Registered protocol family 1
[    0.310523] RPC: Registered named UNIX socket transport module.
[    0.310528] RPC: Registered udp transport module.
[    0.310532] RPC: Registered tcp transport module.
[    0.310535] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.310547] PCI: CLS 0 bytes, default 64
[    0.310741] Trying to unpack rootfs image as initramfs...
[    1.100173] Freeing initrd memory: 11848K
[    1.101486] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    1.101821] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    1.102440] kvm [1]: IPA Size Limit: 40bits
[    1.103977] kvm [1]: vgic-v2@fff20000
[    1.104007] kvm [1]: GIC system register CPU interface enabled
[    1.104199] kvm [1]: vgic interrupt IRQ10
[    1.104433] kvm [1]: Hyp mode initialized successfully
[    1.316341] Initialise system trusted keyrings
[    1.316561] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    1.322785] zbud: loaded
[    1.325157] NFS: Registering the id_resolver key type
[    1.325186] Key type id_resolver registered
[    1.325190] Key type id_legacy registered
[    1.325293] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.325329] ntfs: driver 2.1.32 [Flags: R/W].
[    1.325744] fuse: init (API version 7.31)
[    1.326210] SGI XFS with ACLs, security attributes, quota, no debug enabled
[    1.402036] NET: Registered protocol family 38
[    1.402051] Key type asymmetric registered
[    1.402056] Asymmetric key parser 'x509' registered
[    1.402111] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[    1.402283] io scheduler mq-deadline registered
[    1.402288] io scheduler kyber registered
[    1.402399] io scheduler bfq registered
[    1.412019] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges:
[    1.412041] OF: /pcie@f8000000: Missing device_type
[    1.412065] rockchip-pcie f8000000.pcie:      MEM 0x00fa000000..0x00fbdfffff -> 0x00fa000000
[    1.412085] rockchip-pcie f8000000.pcie:      IO 0x00fbe00000..0x00fbefffff -> 0x00fbe00000
[    1.412755] rockchip-pcie f8000000.pcie: no vpcie12v regulator found
[    1.414133] IPMI message handler: version 39.2
[    1.416534] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    1.416544] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[    1.417760] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    1.417769] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    1.419596] pwm-regulator: supplied by regulator-dummy
[    1.420626] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.422548] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 38, base_baud = 1500000) is a 16550A
[    1.422696] serial serial0: tty port ttyS0 registered
[    1.423491] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 39, base_baud = 1500000) is a 16550A
[    1.423647] printk: console [ttyS2] enabled
[    1.423652] printk: bootconsole [uart8250] disabled
[    1.426338] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    1.430748] spi-nor spi0.0: gd25q128 (16384 Kbytes)
[    1.445919] libphy: Fixed MDIO Bus: probed
[    1.461575] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.461582] ehci-pci: EHCI PCI platform driver
[    1.461625] ehci-platform: EHCI generic platform driver
[    1.463966] ehci-platform fe380000.usb: EHCI Host Controller
[    1.464148] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
[    1.464259] ehci-platform fe380000.usb: irq 30, io mem 0xfe380000
[    1.489243] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[    1.489393] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
[    1.489402] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.489410] usb usb1: Product: EHCI Host Controller
[    1.489416] usb usb1: Manufacturer: Linux 5.9.9-sib1 ehci_hcd
[    1.489422] usb usb1: SerialNumber: fe380000.usb
[    1.490018] hub 1-0:1.0: USB hub found
[    1.490051] hub 1-0:1.0: 1 port detected
[    1.492702] ehci-platform fe3c0000.usb: EHCI Host Controller
[    1.492882] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2
[    1.492980] ehci-platform fe3c0000.usb: irq 32, io mem 0xfe3c0000
[    1.519237] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[    1.519372] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
[    1.519381] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.519388] usb usb2: Product: EHCI Host Controller
[    1.519395] usb usb2: Manufacturer: Linux 5.9.9-sib1 ehci_hcd
[    1.519401] usb usb2: SerialNumber: fe3c0000.usb
[    1.519860] hub 2-0:1.0: USB hub found
[    1.519890] hub 2-0:1.0: 1 port detected
[    1.520534] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.520553] ohci-pci: OHCI PCI platform driver
[    1.520612] ohci-platform: OHCI generic platform driver
[    1.520882] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[    1.521050] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
[    1.521148] ohci-platform fe3a0000.usb: irq 31, io mem 0xfe3a0000
[    1.593429] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.09
[    1.593437] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.593444] usb usb3: Product: Generic Platform OHCI controller
[    1.593450] usb usb3: Manufacturer: Linux 5.9.9-sib1 ohci_hcd
[    1.593456] usb usb3: SerialNumber: fe3a0000.usb
[    1.593921] hub 3-0:1.0: USB hub found
[    1.593953] hub 3-0:1.0: 1 port detected
[    1.594521] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[    1.594709] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4
[    1.594802] ohci-platform fe3e0000.usb: irq 33, io mem 0xfe3e0000
[    1.663401] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.09
[    1.663409] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.663416] usb usb4: Product: Generic Platform OHCI controller
[    1.663423] usb usb4: Manufacturer: Linux 5.9.9-sib1 ohci_hcd
[    1.663428] usb usb4: SerialNumber: fe3e0000.usb
[    1.663885] hub 4-0:1.0: USB hub found
[    1.663915] hub 4-0:1.0: 1 port detected
[    1.664510] uhci_hcd: USB Universal Host Controller Interface driver
[    1.665294] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    1.665471] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 5
[    1.665613] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
[    1.665658] xhci-hcd xhci-hcd.0.auto: irq 228, io mem 0xfe900000
[    1.665962] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
[    1.665970] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.665976] usb usb5: Product: xHCI Host Controller
[    1.665982] usb usb5: Manufacturer: Linux 5.9.9-sib1 xhci-hcd
[    1.665988] usb usb5: SerialNumber: xhci-hcd.0.auto
[    1.666450] hub 5-0:1.0: USB hub found
[    1.666481] hub 5-0:1.0: 1 port detected
[    1.666789] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    1.666956] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 6
[    1.666976] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[    1.667037] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.667136] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.09
[    1.667144] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.667150] usb usb6: Product: xHCI Host Controller
[    1.667156] usb usb6: Manufacturer: Linux 5.9.9-sib1 xhci-hcd
[    1.667162] usb usb6: SerialNumber: xhci-hcd.0.auto
[    1.667607] hub 6-0:1.0: USB hub found
[    1.667639] hub 6-0:1.0: 1 port detected
[    1.668262] usbcore: registered new interface driver uas
[    1.668376] usbcore: registered new interface driver usb-storage
[    1.668412] usbcore: registered new interface driver ums-alauda
[    1.668447] usbcore: registered new interface driver ums-cypress
[    1.668488] usbcore: registered new interface driver ums-datafab
[    1.668523] usbcore: registered new interface driver ums_eneub6250
[    1.668557] usbcore: registered new interface driver ums-freecom
[    1.668596] usbcore: registered new interface driver ums-isd200
[    1.668631] usbcore: registered new interface driver ums-jumpshot
[    1.668665] usbcore: registered new interface driver ums-karma
[    1.668700] usbcore: registered new interface driver ums-onetouch
[    1.668744] usbcore: registered new interface driver ums-realtek
[    1.668784] usbcore: registered new interface driver ums-sddr09
[    1.668820] usbcore: registered new interface driver ums-sddr55
[    1.668855] usbcore: registered new interface driver ums-usbat
[    1.668932] usbcore: registered new interface driver usbserial_generic
[    1.668951] usbserial: USB Serial support registered for generic
[    1.671144] mousedev: PS/2 mouse device common for all mice
[    1.679114] rk808 0-001b: chip id: 0x0
[    1.683191] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    1.683216] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    1.683279] DCDC_REG1: supplied by vcc_sysin
[    1.684103] DCDC_REG2: supplied by vcc_sysin
[    1.684588] DCDC_REG3: supplied by vcc_sysin
[    1.684809] DCDC_REG4: supplied by vcc_sysin
[    1.685323] LDO_REG1: supplied by vcc_sysin
[    1.685682] LDO_REG2: supplied by vcc_sysin
[    1.686058] LDO_REG3: supplied by vcc_sysin
[    1.687384] LDO_REG4: supplied by vcc_sysin
[    1.688416] LDO_REG5: supplied by vcc_sysin
[    1.689339] LDO_REG6: supplied by vcc_sysin
[    1.690383] LDO_REG7: supplied by vcc_sysin
[    1.691277] LDO_REG8: supplied by vcc_sysin
[    1.692309] SWITCH_REG1: supplied by vcc3v3_sys
[    1.692562] SWITCH_REG2: supplied by vcc3v3_sys
[    1.695915] rk808-rtc rk808-rtc: registered as rtc0
[    1.696440] rk808-rtc rk808-rtc: setting system clock to 2020-12-04T08:19:25 UTC (1607069965)
[    1.699175] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[    1.699247] fan53555-reg: supplied by vcc_1v8
[    1.700645] vcc0v9_s3: supplied by vcc_1v8
[    1.703274] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[    1.703304] fan53555-reg: supplied by vcc_1v8
[    1.703849] random: fast init done
[    1.707350] OF: graph: no port node found in /i2c@ff3d0000/fusb30x@22
[    1.724430] device-mapper: uevent: version 1.0.3
[    1.724731] device-mapper: ioctl: 4.42.0-ioctl (2020-02-27) initialised: dm-devel@redhat.com
[    1.726523] cpu cpu0: EM: created perf domain
[    1.728474] cpu cpu4: EM: created perf domain
[    1.731386] sdhci: Secure Digital Host Controller Interface driver
[    1.731388] sdhci: Copyright© Pierre Ossman
[    1.731665] Synopsys Designware Multimedia Card Interface Driver
[    1.732161] dwmmc_rockchip fe310000.mmc: IDMAC supports 32-bit address mode.
[    1.732172] dwmmc_rockchip fe310000.mmc: Using internal DMA controller.
[    1.732183] dwmmc_rockchip fe310000.mmc: Version ID is 270a
[    1.732206] dwmmc_rockchip fe310000.mmc: DW MMC controller at irq 27,32 bit host data width,256 deep fifo
[    1.732336] dwmmc_rockchip fe310000.mmc: allocated mmc-pwrseq
[    1.732340] mmc_host mmc0: card is non-removable.
[    1.859779] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    1.873014] dwmmc_rockchip fe320000.mmc: IDMAC supports 32-bit address mode.
[    1.873035] dwmmc_rockchip fe320000.mmc: Using internal DMA controller.
[    1.873046] dwmmc_rockchip fe320000.mmc: Version ID is 270a
[    1.873084] dwmmc_rockchip fe320000.mmc: DW MMC controller at irq 28,32 bit host data width,256 deep fifo
[    1.873350] dwmmc_rockchip fe320000.mmc: Got CD GPIO
[    1.887327] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    1.899389] usb 2-1: new high-speed USB device number 2 using ehci-platform
[    1.900840] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.902407] mmc2: CQHCI version 5.10
[    1.911280] mmc0: queuing unknown CIS tuple 0x80 (2 bytes)
[    1.913080] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.914878] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.918018] mmc0: queuing unknown CIS tuple 0x80 (7 bytes)
[    1.922335] mmc0: queuing unknown CIS tuple 0x81 (9 bytes)
[    1.929139] mmc2: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[    1.932998] ledtrig-cpu: registered to indicate activity on CPUs
[    1.933717] SMCCC: SOC_ID: ARCH_FEATURES(ARCH_SOC_ID) returned error: fffffffffffffffd
[    1.933824] hid: raw HID events driver © Jiri Kosina
[    1.934026] usbcore: registered new interface driver usbhid
[    1.934031] usbhid: USB HID core driver
[    1.934377] rkvdec ff660000.video-codec: Adding to iommu group 1
[    1.943844] Initializing XFRM netlink socket
[    1.944265] NET: Registered protocol family 10
[    1.967085] Segment Routing with IPv6
[    1.967180] mip6: Mobile IPv6
[    1.967190] NET: Registered protocol family 17
[    1.967463] Key type dns_resolver registered
[    1.968462] registered taskstats version 1
[    1.968472] Loading compiled-in X.509 certificates
[    1.968596] zswap: loaded using pool lzo/zbud
[    1.968930] Key type ._fscrypt registered
[    1.968934] Key type .fscrypt registered
[    1.968937] Key type fscrypt-provisioning registered
[    1.981863] mmc_host mmc0: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[    1.982290] Key type encrypted registered
[    2.009468] mmc2: Command Queue Engine enabled
[    2.009498] mmc2: new HS200 MMC card at address 0001
[    2.010400] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges:
[    2.010435] rockchip-pcie f8000000.pcie:      MEM 0x00fa000000..0x00fbdfffff -> 0x00fa000000
[    2.010447] rockchip-pcie f8000000.pcie:      IO 0x00fbe00000..0x00fbefffff -> 0x00fbe00000
[    2.011030] rockchip-pcie f8000000.pcie: no vpcie12v regulator found
[    2.011054] mmcblk2: mmc2:0001 DA4064 58.2 GiB
[    2.011361] mmcblk2boot0: mmc2:0001 DA4064 partition 1 4.00 MiB
[    2.011838] mmcblk2boot1: mmc2:0001 DA4064 partition 2 4.00 MiB
[    2.012616] mmcblk2rpmb: mmc2:0001 DA4064 partition 3 16.0 MiB, chardev (238:0)
[    2.019249]  mmcblk2: p1 p2
[    2.102662] usb 2-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
[    2.102679] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    2.102690] usb 2-1: Product: USB2.0 Hub
[    2.104258] hub 2-1:1.0: USB hub found
[    2.104664] hub 2-1:1.0: 4 ports detected
[    2.189341] usb 3-1: new low-speed USB device number 2 using ohci-platform
[    2.419448] usb 2-1.2: new high-speed USB device number 3 using ehci-platform
[    2.465446] usb 3-1: New USB device found, idVendor=258a, idProduct=001e, bcdDevice= 1.00
[    2.465465] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.465476] usb 3-1: Product: USB KEYBOARD
[    2.465488] usb 3-1: Manufacturer: HAILUCK CO.,LTD
[    2.475249] input: HAILUCK CO.,LTD USB KEYBOARD as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.0/0003:258A:001E.0001/input/input0
[    2.540361] hid-generic 0003:258A:001E.0001: input,hidraw0: USB HID v1.10 Keyboard [HAILUCK CO.,LTD USB KEYBOARD] on usb-fe3a0000.usb-1/input0
[    2.566524] input: HAILUCK CO.,LTD USB KEYBOARD Mouse as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.1/0003:258A:001E.0002/input/input1
[    2.567280] input: HAILUCK CO.,LTD USB KEYBOARD Touchpad as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.1/0003:258A:001E.0002/input/input2
[    2.567976] input: HAILUCK CO.,LTD USB KEYBOARD System Control as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.1/0003:258A:001E.0002/input/input3
[    2.589610] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[    2.591306] rockchip-pcie: probe of f8000000.pcie failed with error -110
[    2.598670] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[    2.599322] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 7
[    2.599549] xhci-hcd xhci-hcd.2.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
[    2.599644] xhci-hcd xhci-hcd.2.auto: irq 227, io mem 0xfe800000
[    2.600296] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
[    2.600311] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.600323] usb usb7: Product: xHCI Host Controller
[    2.600335] usb usb7: Manufacturer: Linux 5.9.9-sib1 xhci-hcd
[    2.600347] usb usb7: SerialNumber: xhci-hcd.2.auto
[    2.601384] hub 7-0:1.0: USB hub found
[    2.601453] hub 7-0:1.0: 1 port detected
[    2.602033] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[    2.602429] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 8
[    2.602458] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
[    2.602572] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.602773] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.09
[    2.602787] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.602799] usb usb8: Product: xHCI Host Controller
[    2.602810] usb usb8: Manufacturer: Linux 5.9.9-sib1 xhci-hcd
[    2.602821] usb usb8: SerialNumber: xhci-hcd.2.auto
[    2.603884] hub 8-0:1.0: USB hub found
[    2.603941] hub 8-0:1.0: 1 port detected
[    2.606224] of_cfs_init
[    2.606335] of_cfs_init: OK
[    2.606988] ALSA device list:
[    2.606994]  No soundcards found.
[    2.607228] dw-apb-uart ff1a0000.serial: forbid DMA for kernel console
[    2.608373] Freeing unused kernel memory: 2944K
[    2.619946] usb 2-1.2: New USB device found, idVendor=0c45, idProduct=6321, bcdDevice= 0.00
[    2.619963] usb 2-1.2: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[    2.619974] usb 2-1.2: Product: USB Camera
[    2.619984] usb 2-1.2: Manufacturer: Sonix Technology Co., Ltd.
[    2.630358] input: HAILUCK CO.,LTD USB KEYBOARD Consumer Control as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.1/0003:258A:001E.0002/input/input4
[    2.630855] input: HAILUCK CO.,LTD USB KEYBOARD Wireless Radio Control as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.1/0003:258A:001E.0002/input/input5
[    2.631646] hid-generic 0003:258A:001E.0002: input,hiddev96,hidraw1: USB HID v1.10 Mouse [HAILUCK CO.,LTD USB KEYBOARD] on usb-fe3a0000.usb-1/input1
[    2.659850] Run /init as init process
[    2.659860]  with arguments:
[    2.659864]    /init
[    2.659868]  with environment:
[    2.659872]    HOME=/
[    2.659876]    TERM=linux
[    2.659881]    ethaddr=
[    2.659885]    eth1addr=
[    2.659890]    serial=cfecc1fa7d8b2007
[    2.659894]    cgroup_enable=memory
[    2.659898]    cgroup_memory=1
[    2.659903]    vga=current
[    2.738872] random: udevd: uninitialized urandom read (16 bytes read)
[    2.739107] random: udevd: uninitialized urandom read (16 bytes read)
[    2.739146] random: udevd: uninitialized urandom read (16 bytes read)
[    2.771915] udevd[307]: starting eudev-3.2.9
[    2.842950] raid6: Forced to use recovery algorithm neon
[    2.842956] raid6: Forced gen() algo neonx8
[    2.850443] dwmmc_rockchip fe310000.mmc: Successfully tuned phase to 49
[    2.852870] mmc0: new ultra high speed SDR104 SDIO card at address 0001
[    2.862006] xor: measuring software checksum speed
[    2.959261]    8regs    :  2798.400 MB/sec
[    3.059297]    32regs    :  3211.600 MB/sec
[    3.159297]    arm64_neon:  2777.600 MB/sec
[    3.159299] xor: using function: 32regs (3211.600 MB/sec)
[    3.239609] Btrfs loaded, crc32c=crc32c-generic
[  17.689576] random: crng init done
[  17.689590] random: 7 urandom warning(s) missed due to ratelimiting
[  20.053573] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Opts: (null)
[  20.428751] loop: module loaded
[  21.102197] udevd[769]: starting eudev-3.2.9
[  21.266979] es8316 1-0011: Failed to get IRQ 0: -22
[  21.286200] rockchip-vop ff8f0000.vop: Adding to iommu group 2
[  21.295903] rockchip-vop ff900000.vop: Adding to iommu group 3
[  21.297693] rockchip-dp ff970000.edp: no DP phy configured
[  21.303119] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops [rockchipdrm])
[  21.303338] [drm] unsupported AFBC format[3231564e]
[  21.305056] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops [rockchipdrm])
[  21.305391] rockchip-drm display-subsystem: bound ff970000.edp (ops rockchip_dp_component_ops [rockchipdrm])
[  21.305598] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops [rockchipdrm])
[  21.305653] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[  21.312510] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43456-sdio for chip BCM4345/9
[  21.312684] brcmfmac mmc0:0001:1: Direct firmware load for brcm/brcmfmac43456-sdio.bin failed with error -2
[  21.312907] usbcore: registered new interface driver brcmfmac
[  21.317757] hantro_vpu: module is from the staging directory, the quality is unknown, you have been warned.
[  21.331603] hantro-vpu ff650000.video-codec: Adding to iommu group 0
[  21.332848] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-enc as /dev/video1
[  21.332948] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-dec as /dev/video2
[  21.343058] rockchip-rga ff680000.rga: HW Version: 0x03.02
[  21.343383] rockchip-rga ff680000.rga: Registered rockchip-rga as /dev/video3
[  21.359916] Bluetooth: Core ver 2.22
[  21.359947] NET: Registered protocol family 31
[  21.359949] Bluetooth: HCI device and connection manager initialized
[  21.359957] Bluetooth: HCI socket layer initialized
[  21.359962] Bluetooth: L2CAP socket layer initialized
[  21.359968] Bluetooth: SCO socket layer initialized
[  21.363513] panfrost ff9a0000.gpu: clock rate = 500000000
[  21.364831] panfrost ff9a0000.gpu: mali-t860 id 0x860 major 0x2 minor 0x0 status 0x0
[  21.364835] panfrost ff9a0000.gpu: features: 00000000,100e77bf, issues: 00000000,24040400
[  21.364839] panfrost ff9a0000.gpu: Features: L2:0x07120206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
[  21.364841] panfrost ff9a0000.gpu: shader_present=0xf l2_present=0x1
[  21.374557] [drm] Initialized panfrost 1.1.0 20180908 for ff9a0000.gpu on minor 1
[  21.375937] power_supply cw2015-battery: cw2015-battery: Found supply : tcpm-source-psy-4-0022
[  21.375945] power_supply cw2015-battery: cw2015-battery: Found supply : dc-charger
[  21.391577] Bluetooth: HCI UART driver ver 2.3
[  21.391585] Bluetooth: HCI UART protocol H4 registered
[  21.391590] Bluetooth: HCI UART protocol BCSP registered
[  21.391652] Bluetooth: HCI UART protocol LL registered
[  21.391654] Bluetooth: HCI UART protocol ATH3K registered
[  21.391683] Bluetooth: HCI UART protocol Three-wire (H5) registered
[  21.392068] Bluetooth: HCI UART protocol Intel registered
[  21.392229] Bluetooth: HCI UART protocol Broadcom registered
[  21.392232] Driver 'hci_uart_qca' needs updating - please use bus_type methods
[  21.392264] Bluetooth: HCI UART protocol QCA registered
[  21.392374] Bluetooth: HCI UART protocol Marvell registered
[  21.392751] input: gpio-key-lid as /devices/platform/gpio-key-lid/input/input6
[  21.406657] uvcvideo: Found UVC 1.00 device USB Camera (0c45:6321)
[  21.441354] input: USB Camera: USB Camera as /devices/platform/fe3c0000.usb/usb2/2-1/2-1.2/2-1.2:1.0/input/input8
[  21.476667] asoc-simple-card es8316-sound: ASoC: no DMI vendor name!
[  21.480352] input: gpio-key-power as /devices/platform/gpio-key-power/input/input9
[  21.480763] input: rockchip,es8316-codec Headphones as /devices/platform/es8316-sound/sound/card0/input7
[  21.509605] dw-apb-uart ff180000.serial: failed to request DMA
[  21.630559] usbcore: registered new interface driver uvcvideo
[  21.630564] USB Video Class driver (1.1.1)
[  21.684198] Console: switching to colour frame buffer device 240x67
[  21.749971] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device
[  21.750977] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 0
[  21.751013] Bluetooth: hci0: BCM: chip id 130
[  21.751601] Bluetooth: hci0: BCM: features 0x0f
[  21.754003] Bluetooth: hci0: BCM4345C5
[  21.754017] Bluetooth: hci0: BCM4345C5 (003.006.006) build 0000
[  21.754112] Bluetooth: hci0: BCM: firmware Patch file not found, tried:
[  21.754115] Bluetooth: hci0: BCM: 'brcm/BCM4345C5.hcd'
[  21.754117] Bluetooth: hci0: BCM: 'brcm/BCM.hcd'
[  22.028434] input: HAILUCK CO.,LTD USB KEYBOARD Mouse as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.1/0003:258A:001E.0002/input/input10
[  22.029724] input: HAILUCK CO.,LTD USB KEYBOARD Touchpad as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.1/0003:258A:001E.0002/input/input11
[  22.030999] input: HAILUCK CO.,LTD USB KEYBOARD System Control as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.1/0003:258A:001E.0002/input/input12
[  22.100733] input: HAILUCK CO.,LTD USB KEYBOARD Consumer Control as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.1/0003:258A:001E.0002/input/input13
[  22.101522] input: HAILUCK CO.,LTD USB KEYBOARD Wireless Radio Control as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.1/0003:258A:001E.0002/input/input14
[  22.103051] hid-multitouch 0003:258A:001E.0002: input,hiddev96,hidraw1: USB HID v1.10 Mouse [HAILUCK CO.,LTD USB KEYBOARD] on usb-fe3a0000.usb-1/input1
[  22.319550] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
[  22.329615] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[  24.386119] EXT4-fs (dm-1): re-mounted. Opts: (null)
[  24.409490] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[  24.815696] EXT4-fs (mmcblk2p1): mounted filesystem with ordered data mode. Opts: (null)
[  24.823760] EXT4-fs (dm-2): mounted filesystem with ordered data mode. Opts: (null)
[  24.828304] EXT4-fs (dm-3): mounted filesystem with ordered data mode. Opts: (null)
[  24.835426] EXT4-fs (dm-5): mounted filesystem with ordered data mode. Opts: (null)
[  26.831862] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[  26.831868] Bluetooth: BNEP filters: protocol multicast
[  26.831885] Bluetooth: BNEP socket layer initialized
[  28.489269] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[  28.809440] Bluetooth: hci0: command 0xfc18 tx timeout
[  33.129571] vcc3v3_ssd: disabling
[  33.129589] vbus_5vout: disabling
[  33.129597] vcc0v9_s3: disabling
[  36.969521] Bluetooth: hci0: BCM: failed to write update baudrate (-110)
[  36.969528] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[  36.969539] Bluetooth: hci0: Failed to set baudrate
[  39.049563] Bluetooth: hci0: command 0x0c03 tx timeout
[  47.209590] Bluetooth: hci0: BCM: Reset failed (-110)
[  47.560802] bpfilter: Loaded bpfilter_umh pid 1177
[  47.561568] Started bpfilter
[  48.599381] rd 0-5: Disabling EAS, schedutil is mandatory
[  48.949526] Adding 2097148k swap on /dev/mapper/blackholez-swap.  Priority:-2 extents:1 across:2097148k SSFS
[  53.609720] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[  86.249684] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] *ERROR* Timed out trying to load firmware
[  111.194632] lib80211: common routines for IEEE802.11 drivers
[  111.194646] lib80211_crypt: registered algorithm 'NULL'
[  111.210025] r8188eu: module is from the staging directory, the quality is unknown, you have been warned.
[  111.215133] usbcore: registered new interface driver r8188eu
[  134.699978] usb 2-1.1: new high-speed USB device number 4 using ehci-platform
[  134.852680] usb 2-1.1: New USB device found, idVendor=2357, idProduct=010c, bcdDevice= 0.00
[  134.852701] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  134.852713] usb 2-1.1: Product: 802.11n NIC
[  134.852725] usb 2-1.1: Manufacturer: Realtek
[  134.852736] usb 2-1.1: SerialNumber: 00E04C0001
[  134.854708] Chip Version Info: CHIP_8188E_Normal_Chip_TSMC_D_CUT_1T1R_RomVer(0)
[  136.001809] MAC Address = d4:6e:0e:0b:97:ec
[  136.014195] R8188EU: indicate disassoc
[  137.570220] R8188EU: assoc success
[  137.584227] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[  137.630817] 8021q: 802.1Q VLAN Support v1.8
[  142.767654] INPUT packet died: IN=wlan0 OUT= MAC=d4:6e:0e:0b:97:ec:3c:90:66:f1:5b:a3:08:00 SRC=45.79.66.164 DST=192.168.1.8 LEN=69 TOS=0x00 PREC=0x00 TTL=57 ID=15579 DF PROTO=UDP SPT=1414 DPT=1414 LEN=49
[  142.864352] INPUT packet died: IN=wlan0 OUT= MAC=d4:6e:0e:0b:97:ec:3c:90:66:f1:5b:a3:08:00 SRC=45.79.66.164 DST=192.168.1.8 LEN=69 TOS=0x00 PREC=0x00 TTL=57 ID=15632 DF PROTO=UDP SPT=51011 DPT=51011 LEN=49
[  153.002729] INPUT packet died: IN=wlan0 OUT= MAC=d4:6e:0e:0b:97:ec:3c:90:66:f1:5b:a3:08:00 SRC=45.79.66.164 DST=192.168.1.8 LEN=69 TOS=0x00 PREC=0x00 TTL=57 ID=19891 DF PROTO=UDP SPT=51011 DPT=51011 LEN=49
[  163.252855] INPUT packet died: IN=wlan0 OUT= MAC=d4:6e:0e:0b:97:ec:3c:90:66:f1:5b:a3:08:00 SRC=45.79.66.164 DST=192.168.1.8 LEN=69 TOS=0x00 PREC=0x00 TTL=57 ID=22612 DF PROTO=UDP SPT=51011 DPT=51011 LEN=49
[  171.659479] New not syn: IN=wlan0 OUT= MAC=d4:6e:0e:0b:97:ec:3c:90:66:f1:5b:a3:08:00 SRC=23.239.3.170 DST=192.168.1.8 LEN=91 TOS=0x00 PREC=0x00 TTL=58 ID=39030 DF PROTO=TCP SPT=993 DPT=38742 WINDOW=505 RES=0x00 ACK PSH URGP=0
[  171.904487] New not syn: IN=wlan0 OUT= MAC=d4:6e:0e:0b:97:ec:3c:90:66:f1:5b:a3:08:00 SRC=23.239.3.170 DST=192.168.1.8 LEN=91 TOS=0x00 PREC=0x00 TTL=58 ID=39031 DF PROTO=TCP SPT=993 DPT=38742 WINDOW=505 RES=0x00 ACK PSH URGP=0
[  172.152484] New not syn: IN=wlan0 OUT= MAC=d4:6e:0e:0b:97:ec:3c:90:66:f1:5b:a3:08:00 SRC=23.239.3.170 DST=192.168.1.8 LEN=91 TOS=0x00 PREC=0x00 TTL=58 ID=39032 DF PROTO=TCP SPT=993 DPT=38742 WINDOW=505 RES=0x00 ACK PSH URGP=0
[  172.648997] New not syn: IN=wlan0 OUT= MAC=d4:6e:0e:0b:97:ec:3c:90:66:f1:5b:a3:08:00 SRC=23.239.3.170 DST=192.168.1.8 LEN=91 TOS=0x00 PREC=0x00 TTL=58 ID=39033 DF PROTO=TCP SPT=993 DPT=38742 WINDOW=505 RES=0x00 ACK PSH URGP=0
[  173.632247] New not syn: IN=wlan0 OUT= MAC=d4:6e:0e:0b:97:ec:3c:90:66:f1:5b:a3:08:00 SRC=23.239.3.170 DST=192.168.1.8 LEN=91 TOS=0x00 PREC=0x00 TTL=58 ID=39034 DF PROTO=TCP SPT=993 DPT=38742 WINDOW=505 RES=0x00 ACK PSH URGP=0
[  175.056361] New not syn: IN=wlan0 OUT= MAC=d4:6e:0e:0b:97:ec:3c:90:66:f1:5b:a3:08:00 SRC=52.26.177.54 DST=192.168.1.8 LEN=83 TOS=0x00 PREC=0x00 TTL=234 ID=41009 DF PROTO=TCP SPT=443 DPT=37762 WINDOW=118 RES=0x00 ACK PSH URGP=0
[  175.287738] New not syn: IN=wlan0 OUT= MAC=d4:6e:0e:0b:97:ec:3c:90:66:f1:5b:a3:08:00 SRC=52.26.177.54 DST=192.168.1.8 LEN=83 TOS=0x00 PREC=0x00 TTL=234 ID=41010 DF PROTO=TCP SPT=443 DPT=37762 WINDOW=118 RES=0x00 ACK PSH URGP=0
[  175.519599] New not syn: IN=wlan0 OUT= MAC=d4:6e:0e:0b:97:ec:3c:90:66:f1:5b:a3:08:00 SRC=52.26.177.54 DST=192.168.1.8 LEN=83 TOS=0x00 PREC=0x00 TTL=234 ID=41011 DF PROTO=TCP SPT=443 DPT=37762 WINDOW=118 RES=0x00 ACK PSH URGP=0
[  175.617839] New not syn: IN=wlan0 OUT= MAC=d4:6e:0e:0b:97:ec:3c:90:66:f1:5b:a3:08:00 SRC=23.239.3.170 DST=192.168.1.8 LEN=91 TOS=0x00 PREC=0x00 TTL=58 ID=39035 DF PROTO=TCP SPT=993 DPT=38742 WINDOW=505 RES=0x00 ACK PSH URGP=0
[  175.983871] New not syn: IN=wlan0 OUT= MAC=d4:6e:0e:0b:97:ec:3c:90:66:f1:5b:a3:08:00 SRC=52.26.177.54 DST=192.168.1.8 LEN=83 TOS=0x00 PREC=0x00 TTL=234 ID=41012 DF PROTO=TCP SPT=443 DPT=37762 WINDOW=118 RES=0x00 ACK PSH URGP=0
[  176.911873] New not syn: IN=wlan0 OUT= MAC=d4:6e:0e:0b:97:ec:3c:90:66:f1:5b:a3:08:00 SRC=52.26.177.54 DST=192.168.1.8 LEN=83 TOS=0x00 PREC=0x00 TTL=234 ID=41013 DF PROTO=TCP SPT=443 DPT=37762 WINDOW=118 RES=0x00 ACK PSH URGP=0
[  178.773373] New not syn: IN=wlan0 OUT= MAC=d4:6e:0e:0b:97:ec:3c:90:66:f1:5b:a3:08:00 SRC=52.26.177.54 DST=192.168.1.8 LEN=83 TOS=0x00 PREC=0x00 TTL=234 ID=41014 DF PROTO=TCP SPT=443 DPT=37762 WINDOW=118 RES=0x00 ACK PSH URGP=0
[  179.584559] New not syn: IN=wlan0 OUT= MAC=d4:6e:0e:0b:97:ec:3c:90:66:f1:5b:a3:08:00 SRC=23.239.3.170 DST=192.168.1.8 LEN=91 TOS=0x00 PREC=0x00 TTL=58 ID=39036 DF PROTO=TCP SPT=993 DPT=38742 WINDOW=505 RES=0x00 ACK PSH URGP=0
[  182.514738] New not syn: IN=wlan0 OUT= MAC=d4:6e:0e:0b:97:ec:3c:90:66:f1:5b:a3:08:00 SRC=52.26.177.54 DST=192.168.1.8 LEN=83 TOS=0x00 PREC=0x00 TTL=234 ID=41015 DF PROTO=TCP SPT=443 DPT=37762 WINDOW=118 RES=0x00 ACK PSH URGP=0
[  183.498489] INPUT packet died: IN=wlan0 OUT= MAC=d4:6e:0e:0b:97:ec:3c:90:66:f1:5b:a3:08:00 SRC=45.79.66.164 DST=192.168.1.8 LEN=69 TOS=0x00 PREC=0x00 TTL=57 ID=29395 DF PROTO=UDP SPT=51011 DPT=51011 LEN=49
[  185.057102] Invalid packet: IN=wlan0 OUT= MAC=d4:6e:0e:0b:97:ec:3c:90:66:f1:5b:a3:08:00 SRC=52.26.177.54 DST=192.168.1.8 LEN=114 TOS=0x00 PREC=0x00 TTL=234 ID=41016 DF PROTO=TCP SPT=443 DPT=37762 WINDOW=118 RES=0x00 ACK PSH FIN URGP=0
[  187.840748] New not syn: IN=wlan0 OUT= MAC=d4:6e:0e:0b:97:ec:3c:90:66:f1:5b:a3:08:00 SRC=23.239.3.170 DST=192.168.1.8 LEN=91 TOS=0x00 PREC=0x00 TTL=58 ID=39037 DF PROTO=TCP SPT=993 DPT=38742 WINDOW=505 RES=0x00 ACK PSH URGP=0
[  189.935978] Invalid packet: IN=wlan0 OUT= MAC=d4:6e:0e:0b:97:ec:3c:90:66:f1:5b:a3:08:00 SRC=52.26.177.54 DST=192.168.1.8 LEN=145 TOS=0x00 PREC=0x00 TTL=234 ID=41017 DF PROTO=TCP SPT=443 DPT=37762 WINDOW=118 RES=0x00 ACK PSH FIN URGP=0
[  203.499240] INPUT packet died: IN=wlan0 OUT= MAC=d4:6e:0e:0b:97:ec:3c:90:66:f1:5b:a3:08:00 SRC=45.79.66.164 DST=192.168.1.8 LEN=584 TOS=0x00 PREC=0x00 TTL=57 ID=39978 DF PROTO=UDP SPT=1414 DPT=1414 LEN=564
[  203.712738] New not syn: IN=wlan0 OUT= MAC=d4:6e:0e:0b:97:ec:3c:90:66:f1:5b:a3:08:00 SRC=23.239.3.170 DST=192.168.1.8 LEN=91 TOS=0x00 PREC=0x00 TTL=58 ID=39038 DF PROTO=TCP SPT=993 DPT=38742 WINDOW=505 RES=0x00 ACK PSH URGP=0
[  204.783691] Invalid packet: IN=wlan0 OUT= MAC=d4:6e:0e:0b:97:ec:3c:90:66:f1:5b:a3:08:00 SRC=52.26.177.54 DST=192.168.1.8 LEN=145 TOS=0x00 PREC=0x00 TTL=234 ID=41018 DF PROTO=TCP SPT=443 DPT=37762 WINDOW=118 RES=0x00 ACK PSH FIN URGP=0
[  213.868332] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[  213.868344] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[  213.872075] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[  213.872089] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[  213.873577] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[  213.873588] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[  213.875470] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[  213.875481] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[  213.877404] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[  213.877415] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[  213.887861] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[  213.887872] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[  213.905525] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[  213.905539] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[  213.907285] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[  213.907296] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[  213.908668] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[  213.908680] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[  213.910276] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[  213.910287] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[  213.912653] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[  213.912664] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[  213.922621] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[  213.922628] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[  213.926832] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[  213.926850] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[  213.933024] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[  213.933032] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[  213.933129] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[  213.933132] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[  213.938876] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[  213.938884] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[  213.944084] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[  213.944091] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[  213.944182] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[  213.944184] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[  219.165222] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[  219.165241] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[  219.173678] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[  219.173696] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[  222.980475] INPUT packet died: IN=wlan0 OUT= MAC=d4:6e:0e:0b:97:ec:3c:90:66:f1:5b:a3:08:00 SRC=45.79.66.164 DST=192.168.1.8 LEN=69 TOS=0x00 PREC=0x00 TTL=57 ID=46741 DF PROTO=UDP SPT=51011 DPT=51011 LEN=49
[  234.739028] Invalid packet: IN=wlan0 OUT= MAC=d4:6e:0e:0b:97:ec:3c:90:66:f1:5b:a3:08:00 SRC=52.26.177.54 DST=192.168.1.8 LEN=145 TOS=0x00 PREC=0x00 TTL=234 ID=41019 DF PROTO=TCP SPT=443 DPT=37762 WINDOW=118 RES=0x00 ACK PSH FIN URGP=0
[  235.457176] New not syn: IN=wlan0 OUT= MAC=d4:6e:0e:0b:97:ec:3c:90:66:f1:5b:a3:08:00 SRC=23.239.3.170 DST=192.168.1.8 LEN=91 TOS=0x00 PREC=0x00 TTL=58 ID=39039 DF PROTO=TCP SPT=993 DPT=38742 WINDOW=505 RES=0x00 ACK PSH URGP=0
[  243.413442] INPUT packet died: IN=wlan0 OUT= MAC=d4:6e:0e:0b:97:ec:3c:90:66:f1:5b:a3:08:00 SRC=45.79.66.164 DST=192.168.1.8 LEN=69 TOS=0x00 PREC=0x00 TTL=57 ID=55282 DF PROTO=UDP SPT=51011 DPT=51011 LEN=49
[  263.258572] INPUT packet died: IN=wlan0 OUT= MAC=d4:6e:0e:0b:97:ec:3c:90:66:f1:5b:a3:08:00 SRC=45.79.66.164 DST=192.168.1.8 LEN=69 TOS=0x00 PREC=0x00 TTL=57 ID=64191 DF PROTO=UDP SPT=51011 DPT=51011 LEN=49
[  283.402707] INPUT packet died: IN=wlan0 OUT= MAC=d4:6e:0e:0b:97:ec:3c:90:66:f1:5b:a3:08:00 SRC=45.79.66.164 DST=192.168.1.8 LEN=69 TOS=0x00 PREC=0x00 TTL=57 ID=7802 DF PROTO=UDP SPT=51011 DPT=51011 LEN=49
[  301.506323] New not syn: IN=wlan0 OUT= MAC=d4:6e:0e:0b:97:ec:3c:90:66:f1:5b:a3:08:00 SRC=23.239.3.170 DST=192.168.1.8 LEN=91 TOS=0x00 PREC=0x00 TTL=58 ID=39040 DF PROTO=TCP SPT=993 DPT=38742 WINDOW=505 RES=0x00 ACK PSH URGP=0
[  303.509432] INPUT packet died: IN=wlan0 OUT= MAC=d4:6e:0e:0b:97:ec:3c:90:66:f1:5b:a3:08:00 SRC=45.79.66.164 DST=192.168.1.8 LEN=588 TOS=0x00 PREC=0x00 TTL=57 ID=20560 DF PROTO=UDP SPT=1414 DPT=1414 LEN=568
[  324.683436] INPUT packet died: IN=wlan0 OUT= MAC=d4:6e:0e:0b:97:ec:3c:90:66:f1:5b:a3:08:00 SRC=45.79.66.164 DST=192.168.1.8 LEN=69 TOS=0x00 PREC=0x00 TTL=57 ID=31501 DF PROTO=UDP SPT=51011 DPT=51011 LEN=49
[  343.511857] INPUT packet died: IN=wlan0 OUT= MAC=d4:6e:0e:0b:97:ec:3c:90:66:f1:5b:a3:08:00 SRC=45.79.66.164 DST=192.168.1.8 LEN=584 TOS=0x00 PREC=0x00 TTL=57 ID=43253 DF PROTO=UDP SPT=1414 DPT=1414 LEN=564
[  424.389363] New not syn: IN=wlan0 OUT= MAC=d4:6e:0e:0b:97:ec:3c:90:66:f1:5b:a3:08:00 SRC=23.239.3.170 DST=192.168.1.8 LEN=91 TOS=0x00 PREC=0x00 TTL=58 ID=39041 DF PROTO=TCP SPT=993 DPT=38742 WINDOW=505 RES=0x00 ACK PSH URGP=0
RE: slarm64 (unofficial slackware) Pinebook Pro RK3399 (aarch64) - by globaltree - 12-04-2020, 03:07 AM
  Debian on Pinebook Pro u974615 7 1,374 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,850 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,250 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,351 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 90,120 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,396 11-23-2023, 07:37 AM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,531 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,580 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Install deepin OS on pinebook pro wangyukunshan 4 1,676 08-07-2023, 01:12 PM
Last Post: myself600
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 694 07-13-2023, 05:21 PM
Last Post: owaspfap
