Save your sanity: If you buy a PBP, buy a serial adapter and USB to eMMC adapter.
It's about $15.
One thing I'm seeing, fairly consistently, is problems on the forum that are borderline impossible to troubleshoot without serial output.
Due to how the PBP brings up the display, it has to get quite far into the boot process before you'll see anything beyond the status LED.  Troubleshooting "LED comes on, nothing else happens" without the serial output is both challenging and frustrating.
With the serial output from the various stages of boot firmware and potentially early kernel, troubleshooting becomes very straightforward, because all the stages are fairly verbose and tell you what's wrong if they can't proceed.
Also, given the boot ROM's rather odd preference to pull firmware from the eMMC before searching the SD card, a corrupt eMMC will easily prevent the system from booting, and it's quite annoying to correct.
With a UART and the USB eMMC adapter, both of these problem classes become radically easier to troubleshoot and fix.
So buy (or build) the proper adapters.  Please.  It's still very much beta, rough around the edges hardware in early boot, and it would be really nice to be able to be more helpful.
Save your sanity: If you buy a PBP, buy a serial adapter and USB to eMMC adapter. - by Syonyk - 06-29-2020, 11:13 AM
  Happy eMMC and SDcard OS usage for Pinebook Pro Newbies... Paulie420 42 60,428 11-20-2023, 06:22 PM
  serial cable 2023 thread bsammon 2 1,224 07-20-2023, 10:13 AM
Last Post: bsammon
  I'm booting from NVME but I want to switch back to eMMC acruhl 4 1,503 04-23-2023, 06:58 AM
Last Post: acruhl
  Doesn’t power on after flashing emmc badguru 3 1,264 02-25-2023, 09:00 PM
Last Post: badguru
  eMMC problem with Tow-Boot/u-boot on SPI repa 3 1,731 02-21-2023, 01:49 AM
Last Post: repa
  Partial boot after installing Manjaro on emmc regivanx 11 3,204 02-06-2023, 09:11 AM
  Unable to Boot anything (emmc or SDcard) line72 5 2,038 01-17-2023, 12:07 PM
Last Post: nfms
  What OS have you recently flashed onto PBP eMMC? jcun4128 6 2,401 11-26-2022, 09:39 AM
  Unable to boot from emmc after flashing it rfm83 3 1,806 11-08-2022, 10:59 PM
Last Post: rfm83
  Pinebook picky about which EMMC will boot flatulent_piney 8 3,100 11-05-2022, 06:03 PM
Last Post: ajtravis
