Doesn’t power on after flashing emmc
So i tried using the pine64 usb emmc adapter to flash manjaro to emmc, now the pbp will not power on at all no lights no screen on, nothing. help
exactly what image?
Have you tried to boot a known good uSD? (& then with emmc disabled)
It seems some manjaro images have no uboot in 1st 16M,
with no uboot you have an apparently dead pbp
If you picked a "pinebook" image (rather than pinebookpro),, this is for A64 cpu's,,
the uboot is WRONG, you have to do a hard reset to recover
(internal reset button OR press and hold pwr 20+ sec)
OR, it just could be a defective uboot
Not to simply be pedantic but I think it's important;
Your PBP does turn on, it just doesn't boot. The power light gets turned on by software, usually in U-Boot. Do heed wdt.
:wq
[ SRA accepts you ]
Thank you for your replies but i got it worked out. I started by flashing kali which worked. Then i figured out how to flash tow boot. Again thanks for your replies
  Video Flashing/adjusting on boot and reboot jbradley419 0 290 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,226 12-15-2023, 02:11 PM
  Happy eMMC and SDcard OS usage for Pinebook Pro Newbies... Paulie420 42 60,207 11-20-2023, 06:22 PM
  Lockable-until-power-cycle persistent storage Melab 0 719 09-17-2023, 08:51 PM
Last Post: Melab
  power on Pinebook Pro mainboard without keyboard? papable 0 840 07-20-2023, 11:06 PM
Last Post: papable
  I'm booting from NVME but I want to switch back to eMMC acruhl 4 1,497 04-23-2023, 06:58 AM
Last Post: acruhl
  When does Pinebook Pro power LED go on? Bram 0 633 03-14-2023, 09:53 AM
Last Post: Bram
  Pinebook Pro won't turn on after flashing image Idaho 2 1,105 02-21-2023, 02:31 PM
Last Post: Idaho
  eMMC problem with Tow-Boot/u-boot on SPI repa 3 1,729 02-21-2023, 01:49 AM
Last Post: repa
  Partial boot after installing Manjaro on emmc regivanx 11 3,193 02-06-2023, 09:11 AM
