serial cable 2023 thread
So... is anyone selling a proper (fully compatible) serial console cable for the Pinebook pro ?
My impression from reading older threads is that 3.0V is ideal, 3.3V usually works, and 5.0V (which the Pine64 store was selling as PBP compatible) is unreliable.
Have any stores stepped up to sell proper cables for this?
Does everyone just have to solder their own cables together?
I want to experiment with alternative bootloaders and maybe firmwares, and it sounds like a serial console would be essential for when things inevitably go wrong.
(07-18-2023, 02:54 PM)bsammon Wrote: So... is anyone selling a proper (fully compatible) serial console cable for the Pinebook pro ?
You can use this PinePhone serial console info on Pinebook Pro: https://wiki.pine64.org/wiki/PinePhone#Serial_console. Just the speed set to 1500000.
The ready cable can be acquired at Pine Store: https://pine64.com/product/pinebook-pine...l-console/
Thank you! I had found a $15 cable on Amazon and a $25 cable on Mouser (in the USA market), so this is better.
Note: it would be good to mention on that Pine Store page what voltage that serial cable uses.  I'm going to give Pine64-company the benefit of the doubt here, but it would be good to be explicit.
Tongue Yet another Pinebook Pro won't boot thread pinemouth 4 2,440 05-20-2023, 01:02 AM
Last Post: jackwilson
  1000th thread KidTechnical 0 694 12-20-2022, 09:26 AM
Last Post: KidTechnical
  Pinebook Pro - Display cable broken? snokis 0 1,522 08-17-2021, 11:30 AM
Last Post: snokis
  The RK3399 Overclock/Undervolt/Voltages Thread generaleramon 36 32,555 06-11-2021, 03:02 AM
Last Post: dsimic
  Serial port cable bsammon 17 24,587 03-04-2021, 10:00 AM
Last Post: mattpenn
  Serial console accessible from outside as400 4 5,269 10-23-2020, 11:21 AM
Last Post: as400
  Pinebook Pro doesn't boot most of the time unless connected via USB-serial! nib0 16 13,372 09-29-2020, 10:24 PM
  Save your sanity: If you buy a PBP, buy a serial adapter and USB to eMMC adapter. Syonyk 11 13,010 06-30-2020, 10:28 AM
Last Post: manawyrm
Photo Looking for a PBP NVMe/SSD cable ab1jx 13 14,605 06-07-2020, 01:24 PM
Last Post: ab1jx
