Unable to boot from emmc after flashing it
I have a working pbpro with a working emmc which I have flashed several times with different images. No issues until I incorrectly flashed it with an Arch image.
Now I'm unable to boot from it. When powering on the device, the power light stays solid amber with a black screen. No activity at all.
This happens with or without a bootable SD card inserted.
However, I figured out that the machine boots from the SD card only if I disable the physical emmc switch on the inside. If I switch it back on during boot up or after the OS is already running from SD card, the emmc is not recognized at all. Does it mean I possibly bricked it? Is there any other workaround to try to make the emmc show up again after booting from the SD card?
I'm trying to get a hold of a emmc to USB adapter to see if it's readable on another device.
Has anyone experienced anything similar?
Yes; I would say it's pretty easy to cause this to happen. No, you haven't bricked anything. Something in your boot is crashing, probably U-boot. Your eMMC is working, else the power lamp (which is controlled solely by software) would not light. If you can afford to wipe the eMMC and rewrite it from scratch, then simply do that. You'll have to disable it; boot from SD; and early in the boot process, re-enable the eMMC. I know there can be ways to enable the eMMC after booting, but I am not familiar with how to do it. If you get an eMMC to USB adaptor, you can just re-flash it with a working image that way.
:wq
From the wiki, emmc section
echo fe330000.mmc >/sys/bus/platform/drivers/sdhci-arasan/unbind
echo fe330000.mmc >/sys/bus/platform/drivers/sdhci-arasan/bind
(Note: with the device trees coming with older kernels (Linux < 5.11), the device name may be fe330000.sdhci instead of fe330000.mmc)
lsblk to see if it shows up
flipping the disable/enable switch (to enable) @ aprox 4 sec into boot
perhaps the command is easier, but you have to flip the switch anyway
Thanks for replying guys. I was able to get the emmc to show up again by flipping the physical switch and enable it early on in the boot process. Now I can just reflash it again.
Sad What to can't boot from TF card, EMMC system broken - any advice?do guys? qingss0 1 2,330 12-18-2025, 01:05 AM
Last Post: qingss0
  swap eMMC advice jceaser 2 2,645 10-23-2025, 09:59 PM
  Need new eMMC Karsten1 2 4,794 10-23-2025, 09:38 AM
Last Post: jceaser
  Bonk to boot biketool 2 2,955 10-21-2025, 09:08 AM
  3 days in, slow/stuck or no boot. lgmpbp2 34 33,421 06-11-2025, 08:53 AM
Last Post: lgmpbp2
  upgrading u-boot--what version? where to get it? bsammon 14 20,545 04-03-2025, 07:47 AM
Last Post: Tazdevl
Tongue Yet another Pinebook Pro won't boot thread pinemouth 5 12,917 12-27-2024, 11:38 AM
Last Post: akash3995
  broken tow-boot hashkeeper 1 4,589 12-25-2024, 10:12 PM
Last Post: jessipinkman
  Unable to use umlaut key combos ili 4 5,974 12-02-2024, 03:56 PM
  Cant boot into an OS trashtendenz 3 5,968 10-23-2024, 03:49 AM
Last Post: chaylengordon
