Power consumption and suspend to ram
#33
(11-30-2020, 01:29 PM)3xC0MM Wrote:
(11-30-2020, 12:47 PM)wdt Wrote: It took a few minutes to "puzzle out" what has happened here
When you did install of bsp uboot, it does 2 things, put uboot files in /boot for you to dd,
AND change extlinux,conf,, wrongly, the root=  statement is now wrong (on emmc), not on SD
boot flow, with this mixed up boot, uboot (emmc) -> extlinux.conf (SD) ->rootfs (emmc)
so... edit extlinux.conf (emmc) to have correct root=
sudo blkid  will show all
And, BTW, 5.9 cannot do suspend 3, s3, s2mem, suspend to mem
(what version? uname -r or ls /lib/modules/)
If you want this, have to downgrade to 5.8, if it is in /var/cache/pacman/pkgs/ is a lot easier (pacman -U something)
Be sure that the boot is sorted first, of course
Thank you very much for looking into this.
You are right, the extlinux.conf had a wrong entry under root=, so I modified it and the emmc now boots, but the screen is still blank.
I will boot from a clean SD and rewrite the default uboot on the emmc. So I will stick to it, as I do not know how to downgrade to 5.8. I wanted the S3 to work, because as of now leaving the PBP to sleep consumes the battery fast.
Is there any easy way to enable the S3?
Cheers!
For whatever reson u-boot.itb was not present in the /boot. I copied it there from the SD card and now I am able to boot from the emmc.
Thank you very much!
Now I just need to see how can I resolve the S3 activation. Smile
Power consumption and suspend to ram - by robt - 06-14-2020, 03:01 PM
RE: Power consumption and suspend to ram - by wdt - 06-15-2020, 10:42 AM
RE: Power consumption and suspend to ram - by wdt - 06-19-2020, 05:22 PM
RE: Power consumption and suspend to ram - by wdt - 08-03-2020, 08:00 AM
RE: Power consumption and suspend to ram - by wdt - 11-30-2020, 12:47 PM
RE: Power consumption and suspend to ram - by User 18041 - 11-30-2020, 02:50 PM
RE: Power consumption and suspend to ram - by wdt - 11-30-2020, 04:32 PM
  Lockable-until-power-cycle persistent storage Melab 0 758 09-17-2023, 08:51 PM
Last Post: Melab
  power on Pinebook Pro mainboard without keyboard? papable 0 868 07-20-2023, 11:06 PM
Last Post: papable
  When does Pinebook Pro power LED go on? Bram 0 650 03-14-2023, 09:53 AM
Last Post: Bram
  Doesn’t power on after flashing emmc badguru 3 1,307 02-25-2023, 09:00 PM
Last Post: badguru
Heart Now better battery life or power management? KC9UDX 5 2,377 09-09-2022, 08:13 PM
  high battery drain on suspend/poweroff wiz 5 5,185 02-10-2022, 11:52 AM
  Replacement Power Cord recommendation? nathanielwheeler 3 3,363 01-23-2021, 06:43 PM
  power light blinking during charge when pbpro is off Idaho 0 1,830 01-04-2021, 10:53 AM
Last Post: Idaho
  Taming the power switch? ab1jx 4 4,966 11-30-2020, 10:57 PM
Last Post: rimaille
Exclamation Seemingly lost power permanently now /cry jimsurvak 2 3,131 11-16-2020, 06:22 PM
Last Post: jimsurvak
