Replacement Power Cord recommendation?
A few months ago, I dropped my Pinebook Pro.  Not from very high, about desk level.  The system continued operating as normal, but I found that the power cord had snapped.  I have tried ordering replacements based on the specs of the DC cord listed on the website, but none of the replacements have fit in.
Does anyone have any power cord replacement recommendations?  I'd greatly appreciate it.
The cord broke?? I would expect that there is more damage!
You can buy the whole wall wart power supply for ~£10.
https://pine64.com/product/rock64-pinebo...46c16e2e66
I suspect that you'll also need a new PCB with barrel jack, but I don't see that for sale.
Many users don't even use that charger, as you can charge the PBP with a USB-C charger. However, I feel that the barrel jack is a better solution.
Yeah, it landed on a weird angle right on top of the cord.  I was really surprised that nothing on my system was affected.  I mean, I'm running it right now.
I've had to use the USB-C for charging since then, but I find that not all USB-Cs are created equal.  The only one I could get to supply it with power were my USB-Cs from Canakit, designed for the Pi.  But yeah, like you said, I'd like a more dedicated charging solution.
My only concern is that the little board that the barrel jack is mounted on is broken. That, and/or the barrel jack itself. To tear the copper conductors and their PVC covers takes more than enough force to break both of those things.
  Pinebook64 Pro doesn't power on andrea_from_italy 9 9,292 03-20-2025, 10:07 AM
  Lockable-until-power-cycle persistent storage Melab 0 2,762 09-17-2023, 08:51 PM
Last Post: Melab
  power on Pinebook Pro mainboard without keyboard? papable 0 3,048 07-20-2023, 11:06 PM
Last Post: papable
  When does Pinebook Pro power LED go on? Bram 0 2,706 03-14-2023, 09:53 AM
Last Post: Bram
  Doesn’t power on after flashing emmc badguru 3 5,524 02-25-2023, 09:00 PM
Last Post: badguru
Heart Now better battery life or power management? KC9UDX 5 7,104 09-09-2022, 08:13 PM
  pbp replacement board altacus 0 2,290 01-10-2022, 11:27 AM
Last Post: altacus
  power light blinking during charge when pbpro is off Idaho 0 4,351 01-04-2021, 10:53 AM
Last Post: Idaho
  Taming the power switch? ab1jx 4 12,096 11-30-2020, 10:57 PM
Last Post: rimaille
  Power consumption and suspend to ram robt 33 74,133 11-30-2020, 04:32 PM
