pinebook pro tools
#37
(07-30-2020, 04:52 PM)xmixahlx Wrote: you should be able to include the linux hwaccel patch for general arm use. ffmpeg would probably have separate ffmpeg-v4l2request (rockchip) and ffmpeg-v4l2 (allwinner) packages. kodi could be a separate kodi-gles package. i'm not actually sure how conflicts and provides work in manjaro/arch, but it would be "straightforward" with debian, which is what i planned to do eventually.
Thanks. Now that I am sure everything works as per your test, I will start looking into this and try to build the ffmpeg again for rk along with general ffmpeg config and then might also rebuild kodi as you said will rename it kodi-gles.
I hope it works with the packages.
Currently we're on 5.8.1
Thank for your response.
Hi @xmixahlx
I am going through the tools again, Just wanted to know as we're already on the latest kernel and mesa package, I just have to build ffmpeg with the patch provided in the resource right ?
Or do I have to build all the libs needed for ffmepg which you have provided in the pbp-tools git ?
Manjaro ARM Team.
pinebook pro tools - by xmixahlx - 06-11-2020, 03:09 AM
RE: pinebook pro tools - by Eight Bit - 06-11-2020, 11:29 AM
RE: pinebook pro tools - by xmixahlx - 06-11-2020, 11:47 AM
RE: pinebook pro tools - by xmixahlx - 06-13-2020, 03:22 PM
RE: pinebook pro tools - by Syonyk - 06-13-2020, 03:44 PM
RE: pinebook pro tools - by xmixahlx - 06-13-2020, 06:42 PM
RE: pinebook pro tools - by Odel - 06-14-2020, 04:12 PM
RE: pinebook pro tools - by xmixahlx - 06-14-2020, 04:48 PM
RE: pinebook pro tools - by xmixahlx - 06-18-2020, 01:27 AM
RE: pinebook pro tools - by as400 - 06-18-2020, 12:09 PM
RE: pinebook pro tools - by xmixahlx - 06-19-2020, 02:48 PM
RE: pinebook pro tools - by codanostra - 06-19-2020, 02:58 AM
RE: pinebook pro tools - by xmixahlx - 06-19-2020, 05:13 PM
RE: pinebook pro tools - by Syonyk - 06-20-2020, 05:46 PM
RE: pinebook pro tools - by xmixahlx - 06-19-2020, 06:38 PM
RE: pinebook pro tools - by as400 - 06-21-2020, 09:00 AM
RE: pinebook pro tools - by xmixahlx - 06-21-2020, 09:36 AM
RE: pinebook pro tools - by xmixahlx - 06-24-2020, 04:28 PM
RE: pinebook pro tools - by xmixahlx - 06-27-2020, 05:03 PM
RE: pinebook pro tools - by xmixahlx - 06-29-2020, 08:11 PM
RE: pinebook pro tools - by xmixahlx - 06-30-2020, 04:17 PM
RE: pinebook pro tools - by Odel - 07-02-2020, 12:56 AM
RE: pinebook pro tools - by xmixahlx - 07-02-2020, 09:20 AM
RE: pinebook pro tools - by Odel - 07-03-2020, 10:19 PM
RE: pinebook pro tools - by xmixahlx - 07-07-2020, 03:34 PM
RE: pinebook pro tools - by xmixahlx - 07-13-2020, 11:18 PM
RE: pinebook pro tools - by charlespine - 07-19-2020, 01:55 AM
RE: pinebook pro tools - by xmixahlx - 07-19-2020, 02:33 AM
RE: pinebook pro tools - by charlespine - 07-19-2020, 10:41 AM
RE: pinebook pro tools - by charlespine - 07-20-2020, 01:53 PM
RE: pinebook pro tools - by xmixahlx - 07-21-2020, 12:13 AM
RE: pinebook pro tools - by xmixahlx - 07-25-2020, 01:53 AM
RE: pinebook pro tools - by spikerguy - 07-30-2020, 12:43 PM
RE: pinebook pro tools - by xmixahlx - 07-30-2020, 12:55 PM
RE: pinebook pro tools - by spikerguy - 07-30-2020, 04:37 PM
RE: pinebook pro tools - by xmixahlx - 07-30-2020, 04:52 PM
RE: pinebook pro tools - by spikerguy - 08-19-2020, 10:20 AM
RE: pinebook pro tools - by xmixahlx - 08-26-2020, 06:00 PM
RE: pinebook pro tools - by tekk - 08-29-2020, 01:39 PM
RE: pinebook pro tools - by xmixahlx - 08-30-2020, 11:50 AM
RE: pinebook pro tools - by mjhammel - 08-31-2020, 09:32 AM
RE: pinebook pro tools - by xmixahlx - 08-31-2020, 11:16 AM
RE: pinebook pro tools - by mjhammel - 09-02-2020, 10:29 AM
RE: pinebook pro tools - by mjhammel - 09-02-2020, 10:48 AM
RE: pinebook pro tools - by jh76 - 09-14-2020, 10:00 AM
RE: pinebook pro tools - by xmixahlx - 09-19-2020, 10:11 AM
RE: pinebook pro tools - by spikerguy - 11-27-2020, 01:31 PM
RE: pinebook pro tools - by xmixahlx - 12-06-2020, 01:16 PM
RE: pinebook pro tools - by mjhammel - 03-08-2021, 05:33 PM
RE: pinebook pro tools - by mjhammel - 03-12-2021, 06:58 PM
RE: pinebook pro tools - by xmixahlx - 04-03-2021, 04:13 PM
RE: pinebook pro tools - by mjhammel - 04-05-2021, 09:22 AM
  Debian on Pinebook Pro u974615 7 1,412 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,873 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,266 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,367 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 90,238 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,406 11-23-2023, 07:37 AM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,553 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,584 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Install deepin OS on pinebook pro wangyukunshan 4 1,681 08-07-2023, 01:12 PM
Last Post: myself600
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 695 07-13-2023, 05:21 PM
Last Post: owaspfap
