How to install opensuse on Pinebook pro
I am trying to install opensuse on my pinebook pro and feel stupid for asking this ... but how ?
I downloaded the iso from https://github.com/smithmcgriff/openSUSE-on-pinebookpro
and then I put it on an sd card.
My pbp boots from it but all I get is a terminal. I think it just boots from the sd card but how do I get the image to install on the internal drive in the pinebook pro?
Also a small side question:
How bad of an idea is it to simply get the aarch64  image from opensuse (https://software.opensuse.org/distributions/tumbleweed) and install that on the pbp?
(05-16-2020, 02:06 PM)oldmansaur Wrote: Hi,
There are some tips in this thread:
https://forum.pine64.org/showthread.php?tid=9047
You can just write the original opensuse version to a sd card and try if it works. You won’t damage anything that way. I guess you still need to do some configuration though. Also it depends which kernel opensuse is using, currently development in the Pinebook Pro area is very vibrant, so every new kernel offers a bjt more out of the box.
  Debian on Pinebook Pro u974615 7 1,192 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,688 02-22-2024, 04:02 PM
  Attempting to install Void Linux, boots into a black screen 9a3eedi 0 361 02-18-2024, 08:54 AM
Last Post: 9a3eedi
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,197 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,279 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 89,598 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,296 11-23-2023, 07:37 AM
  install debian on pbp jsch 7 4,130 11-22-2023, 04:22 PM
Last Post: TRS-80
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,413 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,519 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
