Kali Linux for Pinebook Pro
#21
Think they mixed up some stuff.
Kali 2020.1a has a bug fix for x11. PBP version seems to be 2020.1 without the patch. After updates mine broke with the same x11 bug. As WDT suggested it's still using the older user/pass.
Im re-writing my SD at the moment. When it's done I'm looking into this: https://bugs.kali.org/view.php?id=6053
[Edit] Just installed "xserver-xorg-input-all" but kali-menu seems to be broken? Il'l try apt-get upgrade and reboot Smile
@Tazdevl
Yes indeed,, complains about a missing directory, which does not exist
So, 1st thing, install something simple*, notice error msg,,, mkdir /usr/share/........
I don't know if this is good enough, but at least shuts up error msg
(*like perhaps "ne", will not install anything else)
--edit--
All the fs errors were from resize2fs, nothing to do with kali
purge kali-undercover,, an update locks computer, repeatedly
Had to remove from status to finish update
Did the folder fix but no real progress here, updates don't work. It hangs on kali-undercover
[edit] slow on waking up... I'll try removing undercover
[edit1 ]sudo dpkg --remove --force-remove-reinstreq kali-undercover helps a lot. But ffs, how many times can you write dpkg wrong?
Looks like 2020.2 version is available. I am still waiting for my pro machine. Can someone report how it works and if any issues?
https://www.offensive-security.com/kali-...rm-images/
https://www.kali.org/news/kali-linux-2020-2-release/
I have it running on a micro SD.
Now you have to login with kali/kali.
Audio is working (didn't work with root in the previous version).
First time it still booted Manjaro from the eMMC, but after a restart it booted up.
(05-13-2020, 05:22 AM)jiyong Wrote: I have it running on a micro SD.
Hi all,
I have it running on a micro SD and I have tried to write the image on the emmc but it looks like I have done something wrong. Should I try with the dd command with unmounted emmc? I send you a screenshot showing fdisk -l info.
I an a newbie with Kali Linux but I am trying to learn.
Thanks, happy and healthy hacking!
Ricardo
.png   Screenshot_2020-05-15_13-47-31.png (Size: 67.7 KB / Downloads: 512)
Hi all,
Ricardo
You need to edit the /etc/default/u-boot and /boot/extlinux.conf to match the emmc.
My recommendation is to use UUIDs instead device names.
Enviado desde mi ONEPLUS A5010 mediante Tapatalk
Hi all,
Ricardo
Hi Miguel,
thanks for the information. I will try to find the way to make this changes.
Happy and healthy hacking!
PS: Miguel, parece que tu tambien eres castellanoparlante. Un saludo desde Alemania!
Ricardo
Hi all,
Ricardo
Hi Miguel,
Ricardo
https://gitlab.com/kalilinux/build-scrip...issues/180
Basically read that issue for instructions.
(En realidad me llamo Edu! Saludos desde España Big Grin)
Hi again,
I will give it a try.
Los pseudonimos son una buena idea en la red!
Acabo de ver que no es un pseudonimo, sino que las prisas me hicieron convertir tu apellido en nombre y ademas leerlo mal :-P
Hi again,
I have tried this but i have no output from command blkid/dev/mmcbl2p2
I will continue searching. I have forgotten to tell that I was able to boot from the emmc but then I had no network a was not able to activate it.
Best regards
  Debian on Pinebook Pro u974615 7 1,420 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,883 02-22-2024, 04:02 PM
  Attempting to install Void Linux, boots into a black screen 9a3eedi 0 408 02-18-2024, 08:54 AM
Last Post: 9a3eedi
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,272 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,369 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 90,288 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,409 11-23-2023, 07:37 AM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,563 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,587 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Install deepin OS on pinebook pro wangyukunshan 4 1,694 08-07-2023, 01:12 PM
Last Post: myself600
