A true mainline Linux Kernel for the Pinebook Pro
#91
Re: Suspend-to-ram,
It looks like TF-A master contains a fix that claims to fix hangs when resuming from a soft-reset, which may be related to the post-suspend hang.
link to the commit: https://git.trustedfirmware.org/TF-A/tru...516b8785ec
(Not super important link, merged to integration 7 days later: https://git.trustedfirmware.org/TF-A/tru...2672630011 )
If that does not fix it for you, you could capture the debug UART, looking for a TF-A or Linux Panic. If you find a TF-A panic, you could raise an issue on trustedfirmware.org here: https://developer.trustedfirmware.org/ma...uery/open/
PS: Hello Pine forums
#92
Can someone post/give-pointers-to a brief set of instructions on how to compile/install this kernel?
I used to compile kernels all the time 15+ years ago, but mostly on x86 (and a few times on my Powerbook)
I just dug up the following website
https://kernelnewbies.org/FAQ/KernelCompilation
which seems to match the way I remember compiling kernels back in the day.
Would those instructions fit this kernel here? I have my doubts about whether "make install" would do what I want/need it to do.
#93
the debian way is to build kernel packages
you need build deps, a kernel config, and 1-2 hours to build
what distro are you building for?
#94
So I did a "git clone https://gitlab.manjaro.org/tsys/linux-pinebook-pro.git" and it was 2.5 GB.
I did a "download as .tar.bz2" from https://gitlab.manjaro.org/tsys/linux-pinebook-pro and it was only 130 MB.
Just ... wow.
(maybe this is a "I'm pretty new to git" moment)
P.S. The time it took for both operations was (to an order of magnitude) proportional to those relative numbers.
#95
yes. for an idea, git has every revision of the repo ever in it...
you can use --depth=1 to get only the latest version and still benefit from the git system.
that is what i do most of the time if just needing source to build from.
#96
hi @tsys , thank you for your mainline work! (also @danielt for your attention)
regarding pinebook_pro_defconfig, please disable the new ARM erratum addition. if enabled the big cores won't come up. an interesting note: without the big cores i get a *970* octane2 score versus *10200* with!!! Smile
# CONFIG_ARM64_ERRATUM_1319367 is not set
also confirming that 5.5-rc7-panfrost-fixes and v5.5 branches work very well on debian sid arm64 with mesa-git.
cheers
#97
Hi @xmixahlx,
(01-30-2020, 11:44 AM)xmixahlx Wrote: regarding pinebook_pro_defconfig, please disable the new ARM erratum addition. if enabled the big cores won't come up. an interesting note: without the big cores i get a *970* octane2 score versus *10200* with!!! Smile
the BIG cores are online on my device with CONFIG_ARM64_ERRATUM_1319367=y. Tasks seem to be scheduled to them as well. Also corrupted TLBs don't sound particularly fun to me. Are you sure I should disable that option?
Manjaro ARM
Kernel dev
Buy me a coffee
#98
I have the same problem with big cores not coming up on boot if I set maxcpus=4 on boot. After boot there is no way to bring them up.
#99
that's an effect of the BSP uboot the device comes with not bringing the big cores up properly. a newer version of uboot does that, making the maxcpus=4 hack and disabling mitigations unnecessary: https://forum.pine64.org/showthread.php?tid=8752
(01-31-2020, 07:07 AM)dhivael Wrote: that's an effect of the BSP uboot the device comes with not bringing the big cores up properly. a newer version of uboot does that, making the maxcpus=4 hack and disabling mitigations unnecessary: https://forum.pine64.org/showthread.php?tid=8752
Problem is that newer version of uboot doesn't support nvme which I'm booting from Smile
  Debian on Pinebook Pro u974615 7 1,425 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,888 02-22-2024, 04:02 PM
  Attempting to install Void Linux, boots into a black screen 9a3eedi 0 413 02-18-2024, 08:54 AM
Last Post: 9a3eedi
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,274 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,374 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 90,331 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,412 11-23-2023, 07:37 AM
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,711 09-07-2023, 09:38 PM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,580 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,597 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
