Can Anyone help me install Wine latest on Rock64
I tried every method and I cant get even old wine to install
I get random messages but when I tried to follow the main websites instructions for latest wine I get
sudo apt install --install-recommends winehq-stable
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 winehq-stable:i386 : Depends: wine-stable:i386 (= 4.0~bionic)
E: Unable to correct problems, you have held broken packages.
Been having the same challenge on the RockPro64...
I installed a Debian Buster image...
Anyway, what I've been able to figure out is that the issue is that FAudio is a dependency and it's this standing in the way.
Found that out by apt-get installing each package listed as a missing dependency, down the chain, until I got stuck at libfaudio0 which is not in any repo (source) that I can find so far (i.e. as per the message above, you'd apt-get install wine-stable:i386, which would then list the next dependency, and so on).
So, there isn't a compatible build for FAudio it seems..
I have subsequently read that building wine yourself *could* work; as in, the dependencies don't all have to be met if building from source (some things may not work as expected then of course).
This is a next step I need to take after getting back to a cleaner version of my OS install after all my tweaking...
Did you ever find a workable solution in your case?
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 159 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,377 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 345 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 631 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 621 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,493 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 191,096 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 605 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 658 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,688 12-07-2022, 08:22 PM
Last Post: luminosity7
