EasyOS 1.0.4 running on Rock64
For anyone who is interested:
http://bkhome.org/news/201902/easyos-ver...ock64.html
To get a quick overview of what EasyOS is all about, see here:
https://easyos.org/about/how-and-why-eas...erent.html
I have been running Easy on the Rock64 for several days, it is completely stable, have been compiling huge packages, such as LibreOffice and the kernel.
Regarding the kernel, thanks to ayufan, I just downloaded from his repo, patched aufs and simplified the .config (mostly took out debugging stuff).
Booted from SD card, I have not yet tried putting it onto the eMMC.
Regards,
BarryK
ok, i'll probably give it a try once i unpack the rock64 [i moved recently]. otherwise, i think "matter" exists in the physical world and comes in various forms. the conscious formulates an internal representation of the matter, this is perception. take for example, your room at night, if you turn on the lights you perceive all types of matter around you, if you turn off the lights and the room is completely dark you perceive nothing since you can not see the matter, however the matter still exists, you just have no internal representation. off topic i know but i just had to throw it out. if you want to continue a discussion on your theory start a thread in general. otherwise, i will let you know what i think about easyos later. thanks.
(02-02-2019, 04:45 AM)BarryK Wrote: For anyone who is interested:
Regards,
BarryK
Hello Barry,
Please advice where should download the EasyOS image file.
I tested easy-1.0.4-aarch64.img.gz (http://distro.ibiblio.org/easyos/aarch64...yro/1.0.4/) where it will stuck after running awhile.
Note Booted from Micro SD Card
Please advice.
Thank you
Pineadmin
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 159 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,377 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 345 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 631 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 621 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,493 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 191,099 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 605 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 658 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,691 12-07-2022, 08:22 PM
Last Post: luminosity7
