Im having weird crashes on a new rock64 [solved]
Hello, i bought a week ago a rock64 4g and about a month ago the hdd im using with it, and im having random crashes and they are getting me crazy, im not sure if they are because of the hdd, the rock64, the psu or what, its runing on a 16mb SD card sandisk ultra (i dont need a bigger SD since im using it as NAS). i tried everything i can imagine and im still having random crashes, im not a very advanced user, but im also not a total noob, its runing actually on the ayufan img omv over jessie arm64 0.5.15, with ssh open when the crash happens i get:
Message from syslogd@omv at Feb  3 20:54:29 ...
 kernel:[ 1401.808948] Internal error: Oops: 96000005 [#1] SMP
 kernel:[ 1402.433932] Process deluged (pid: 2656, stack limit = 0xffffffc0e4be4020)
This is other one about 10 mins after the first, the crazy thing is the timer:
Message from syslogd@omv at Feb  3 19:45:31 ...
 kernel:[  325.419937] Stack: (0xffffffc0fef51ca0 to 0xffffffc0f5e18000)
 kernel:[  325.579292] Code: f2400c84 540001c0 cb040042 36000064 (38401423)
I have no idea what that means, with "cat /var/log/messages" i see nothing at about the time of the crash...
Is there a way to test if its a power problem? dont feel like that since the problem happens randomly, no matter if under heavy load or not (i get around 60mb/s, i guess its normal for a wd elements usb3 hdd), i tried several img, even the latest 0.6.19 and even if i had other problems with that one that im not going to mention here i also had the random crash.
I point to the hdd or anything related because if i stop downloads on my torrent client the crash takes forever to happen, if at all.
The hdd is relativelly new and also its kinda very hard to replace it over a super random problem happening on very specific situations.
Im runing out of ideas, my torrent client (deluge) is runing in a docker, not much protection, but also hard to have config problems that way (in fact everything in the board is runing on dockers exept omv and its services...im going to try another torrent client and report back but i have the feeling that the problem is somewhere else...
Its not a memory problem either, even fully loaded the board stays at about 30% memory used...
Also, the board have 2 small heatsinks and a 5v cooler, that should rule out temp problems imo
Is there any way to test where can be the problem?
Sorry my bad english, its not my native language.
Any help is deeply appreciated, i hope i can solve this...
PS: tried a while with transmission and got this before a crash:
Feb  3 22:15:58 omv kernel: [ 3978.401495] ffprobe[6931]: PC Alignment exception: pc=00000000006671d6 sp=          (null)
Feb  3 22:21:14 omv kernel: [ 4294.712637] ffprobe[7264]: PC Alignment exception: pc=0000000000667132 sp=          (null)
Feb  3 22:40:48 omv kernel: [ 5468.258227] ffprobe[7799]: PC Alignment exception: pc=0000000000667132 sp=          (null)
"Process deluged" that is the deluge daemon. maybe try just running the image without any of the other stuff to see if it is stable alone. then add the hd and run a bit with just that [unless image is on hd of course] then add each package alone and test . adding another until you get crash. then remove last one added and see if once again stable.
(02-04-2018, 01:51 PM)dkryder Wrote: "Process deluged" that is the deluge daemon. maybe try just running the image without any of the other stuff to see if it is stable alone. then add the hd and run a bit with just that [unless image is on hd of course] then add each package alone and test . adding another until you get crash. then remove last one added and see if once again stable.
I did that, up and down, left and right, different versions of distros (all around OMV), EVERYTHING you can imagine of from the point of view of an advanced user, on the end i decided that i needed to try removing OMV from the equation and magic, no more problems (the weird thing is, i even have more speed now without omv, i was getting about 65mb/s speed to/from the drive, now on a simple samba manual setup+deluge it has been stable for several hours and im getting about 90mb/s stable)...omv causes some conflict with my external hdd...anyway, im working on setting all up manually and trying without success to secure samba and connect from w7 (the previous tests where without security of any kind) but at least im runing stable now...another option is to use ftp or sftp, im not extremelly paranoid with security but a drive without a simple user/pass is calling for problems...
TLDR: apparently the "optimizations" that the OMV team use on their distros cause problems with my hdd
Dismiss the OP problem, manually set up system has been runing rock64 solid (pun intended Big Grin) for 10 hours without a problem, downloading at full speed and using the external hdd so the problem is some sort of conflict between OMV and my hdd, im happy now (btw my hdd have no problems at all and its 2 weeks old so im ruling out physical problems (or at least its VERY VERY unlikelly))
Thanks to anyone watching and hopefully this info can help someone else with the same problem in the future...
Awesome! Thanks for the info. Can you edit the title of your post, and maybe add [Solved] or something similar? It would help others possibly experiencing the same issue.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 193 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,426 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 370 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 677 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 660 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,752 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 193,600 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 629 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 679 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 34,533 12-07-2022, 08:22 PM
Last Post: luminosity7
