Please try Slackware Arm Current on Rock64!
This will be a set of scripts I have been using to create a disk image and public images I have created off the current rock64 ayufan kernel and combined with Slackware Arm Current.
Install Instructions:
  1. Download the latest slackware armhf release https://github.com/mwiljanen/slackrock/releases
  2. As a privileged user please run: zcat slackware-current-minimal-rock64-0.5.10-118-armhf.img.gz | sudo dd of=/dev/sdX bs=4M status=progress
  3. I have not created a script to autoexpand the drive so this must be done with gparted.
  4. After boot you can login with user user: rock64 and pass: rock64 this user has sudo access.
  5. To get this image on the internet you must use ifconfig or dhcpcd with an ethernet cable, Network manager is not installed on the slackware-minimal rootfs.
  6. After you get a connection to the internet now you can install all the packages, but do not install the slackwarearm-current kernels, you can blacklist these in the /etc/slackpkg/blacklist. If you install this kernel your rock64 will refuse to boot. To upgrade do these steps:
  • slackpkg update
  • slackpkg install-new
  • slackpkg upgrade-all
This upgrade will take over an hour or more, so please be patient and if you do the full install it will be about +9GB of space on your SD card so a 16GB card is not recommended for a full install.
Now you can enjoy slackware on you Rock64!
Enjoy!
mwiljanen
Thanks for this Smile
Nice work, thanks!
Thank for the great responses, I am very glad to be using Ayufan's kernel with a distro I have been using for years, thanks for the support!
Hi, thanks for the Slack. I've tried using the rock64 - rock64 user and password but it's failing to authenticate. :-(
Sorry. I switched to console and found what I needed. Thanks
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 160 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,377 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 345 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 631 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 622 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,494 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 191,114 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 605 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 658 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,700 12-07-2022, 08:22 PM
Last Post: luminosity7
