Switching from touchscreen to HDMI
Will there be a way eventually to be able to switch from the screen to HDMI and vice versa?
I'm using Android but will eventually will be moving to Ubuntu when it is available for the touch screen.
I believe just switching os will automatically switch to hdmi output. My board came with tpuch screen, and android without touch screen os, and it worked with the hdmi, had to download android with touch screen os to use the touch screen, and it automatically switched to the touch screen. So I'm sure you won't have to do anything other than switching the os sim card.
Would be much better to be able to switch within the OS. I already have a box full of SD cards for all my pi's projects. Would be nice to have one OS and stick with it for primary usage. Shouldn't be to hard to have it auto detect a HDMI connection.
The new LCD Android build is LCD and HDMI concurrent output. However, the native UI resolution for both HAMI and LCD is 1026 x600 which is LCD screen native resolution.
So it's not 1920x1080?
Do you have the link for that new LCD build?
(08-07-2016, 03:47 PM)AUDIOTEK Wrote: So it's not 1920x1080?
There are two builds:
For HDMI output only, the UI resolution is 1920x1080. teh HDMI output is either 720p or 1080p.
For LCD and HDMI simultaneous output, the UI resolution is 1024x600 to match with LCD resolution, the HDMI output is either 720p or 1080p.
Great thanks  Where can I download the LCD and HDMI simultaneous output one?
Something should be possible, though, with work.
For instance my NVIDIA Shield controller (not tablet), handles HDMI <--> Touchscreen.  But, if you do both at the same time, you get either the HDMI scaled poorly on the touchscreen or the touchscreen stretched on the HDMI.
Worse yet when the screen goes into rotation ( I doubt you want to rotate your 55' HDMI TV to match the touchscreen).
But, let's get the Linux LCD working first, then more people will be able to try to duplicate what NVIDIA did.  For instance, I've still been unable to build a running Linux kernel yet and I'm sure a bunch of good developers are in the same boat.
--Ken
Hi, where are you stuck with building a Linux kernel? Are you building a BSP kernel based on longsleep's work or a mainline kernel based on linux-sunxi ?
You can find longsleep's kernel work at his github, it's the basis for running his Ubuntu images or lenny's Debian images or my Gentoo test image as well as info on how to build the different firmwares needed to boot A64 here:
https://github.com/longsleep/build-pine64-image
https://github.com/longsleep/linux-pine64
This is based on the 3.10.x BSP kernel release from Allwinner's Linux SDK, with some community fixes and forwarded to 3.10.102 by longsleep.
For mainline kernel you need to have a look at the linux-sunxi community:
https://linux-sunxi.org/Main_Page
https://linux-sunxi.org/Linux_mainlining_effort
https://linux-sunxi.org/Pine64
Fire219 build some test images for 4.7 you can use headless for testing stuff (mainline doesn't have a video driver yet) with GbE, USB and some low-level interfaces already.
(08-11-2016, 05:56 AM)xalius Wrote: Hi, where are you stuck with building a Linux kernel? Are you building a BSP kernel based on longsleep's work or a mainline kernel based on linux-sunxi ?
Yeah, a bit of topic --- but --- I've tried the longsleep build.  Did all the pulls, etc.  Followed the steps.  May have had trouble with busybox - as when I 'cpio'd my initrd to check the files, I got total garbage.  Found another git that had a "one-shot" script to do the whole thing.....  May try that Friday night.  If nothing else, I can try a different prebuilt initrd image.
I got the linaro aarch64 gnu toolchain 4.9 and the 5.3 arm toolchain.   Put the whole thing in docker.  The idea is to set up a docker container to build the whole thing --- if I can, I'll publish my docker images.
More on topic, though, NVidia has a public git for the open source stuff on the shield controller (that does the HDMI/LCD switch).  May get some ideas out of that.
--Ken
  PINE A64 Ubuntu 18 or 20 IMG with touchscreen? burningkrome 0 610 04-29-2023, 05:13 AM
Last Post: burningkrome
  lcd touch screen and hdmi output moreaujacky 2 5,079 10-24-2018, 07:24 AM
Last Post: lisanke
  No HDMI Display need help with correct uEnv.txt settings dkebler 7 10,596 01-11-2018, 02:52 PM
Last Post: dkebler
  HDMI Compatability rahlquist 5 8,266 07-29-2017, 02:32 AM
Last Post: qwerty2002
  Ongoing HDMI limited compatability rahlquist 39 50,584 05-21-2017, 12:59 PM
Last Post: lbdroid
  No HDMI Output martinarcher 2 6,675 04-28-2017, 07:05 AM
Last Post: martinarcher
  Switching boot source on SOPINE64 stephen fleming 2 3,794 03-07-2017, 07:02 AM
Last Post: xalius
  Integration with E-Ink Touchscreen adamjedgar 3 5,829 02-16-2017, 04:56 AM
Last Post: adamjedgar
  4K HDMI video output medapeta 3 6,715 06-10-2016, 04:36 PM
Last Post: shinobi
  HDMI Issue... LeRoms77 4 7,369 04-19-2016, 02:11 AM
Last Post: LeRoms77
