Impossible to login since the latest update
(02-12-2023, 06:34 AM)anonymous Wrote: Don't be sorry but what is the difference between your settings and mine? Which language do you set on your Pinephone?
Good question... I use german language.
Honestly I also don't really understand why my phone crashed rarely last year (only every few weeks!), crashed every few minutes in january and now... multiple times a day, but no more all the time. What changed between phase 1, 2 and 3? Only apt upgrade. Wierd... Huh
Using encrypted Mobian (bookworm) on pmOS CE Convergence PinePhone (3GB/32GB) as Daily Driver, and Beta Edition Convergence PinePhone (3GB/32GB) with encrypted Mobian (bookworm) as Backup device.
Do you use QWERTZ as keyboard layout? Yes, those crashes are annoying. In my case, it happens when I try to launch anything, Megapixels, Gnome Control Center, Chatty.
I switched back to greetd and it now works Smile
  Auto start application on Phosh login Zebulon Walton 8 3,433 10-14-2023, 06:29 AM
Last Post: alaraajavamma
  No volume control after latest updates Zebulon Walton 19 7,260 09-08-2023, 08:28 AM
Last Post: jessencan
  how to update mobian over tor vusra 13 6,998 07-09-2023, 08:57 PM
Last Post: vusra
  Wifi doesn't work after update nickolas 2 1,257 04-14-2023, 10:07 AM
Last Post: nickolas
  PinePhone won't boot after software update jb2000 2 1,354 03-17-2023, 07:26 AM
Exclamation The latest update of eg25-manager seems to cause frequent disconnections anonymous 12 4,380 11-28-2022, 03:30 PM
Last Post: anonymous
  [Fixed] Phosh crashes frequently after latest updates arno_nuehm 20 8,928 10-14-2022, 05:38 PM
Last Post: Krafter
  Latest Reliable Mobian Build Confirmation Thread Katsujinken 5 2,696 09-27-2022, 08:41 AM
Last Post: Katsujinken
  Wifi issue since last update and held back updates goku499 11 5,378 09-21-2022, 02:39 PM
  [SOLVED] Lost Internet connectivity after recent update drh 3 1,887 09-11-2022, 09:24 PM
