Pinebook Pro freezes when running on battery
I have a recent Pinebook Pro from September 2022 (motherboard bears a 2022/07 QC sticker)
It has an NVME (low power WD) SSD for /home and data only, and Manjaro Linux KDE runs from the eMMC, with latest updates applied.
When running from mains power, the system is perfectly stable. But the power cable is so short !
OTOH when running on battery, even fully charged, it happens very often (twice attempting to write this post) that the system completely freezes with the power LED blinking red/green.
At this point I can only perform a hardware poweroff.
Any clue ?
Kind regards.
I have a very similar setup, but with the NVMe as the root drive and the eMMC just as extra storage. Low-power WD SSD, Manjaro, KDE -- all the same. I mostly run on battery, even, and have never had this fault.
I can tell you that typically the red-green flashing indicates a kernel panic, so you may be able to check dmesg to see if there's any particular module that is failing.
(09-15-2022, 01:33 PM)steeb Wrote: I can tell you that typically the red-green flashing indicates a kernel panic, so you may be able to check dmesg to see if there's any particular module that is failing.
Well a kernel panic is something so brutal that the system doesn't get a chance to log anything to disk when it happens... It just stops.
I don't know Linux very well but does it output something to the serial console when that happens?
:wq
[ SRA accepts you ]
If you don't think there's anything useful about seeing exactly what was happening at the time of the kernel panic, then all I'll do is wish you good luck. Thanks for the education, though.
It appears that setting the NVMe to maximum power state PS2 fixed the issue, as far as I can tell.
  Pinebook Pro Initial Impressions kunger 443 591,394 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,320 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 408 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 314 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 299 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 235 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 684 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 767 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,651 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,259 12-15-2023, 02:11 PM
