alarming sound coming from pinebook pro
A couple days ago I received my Pinebook Pro. Immediately after first boot I started to hear an occasional startling sound coming from the lower half of the machine. It is the kind of sound that reminds me of a speaker getting its cable pulled out (although much "smaller" sounding of course). On the other hand, it plausibly sounds like a fan having a malfunction -- I have not heard a fan on this during use so far, presumably it has one?
If I had to guess, it is coming from the lower left side, e,g, under the caps lock and the meta key. It happens randomly, but at least 5 times in a couple hours of use.
Any ideas?
EDIT:
fwiw, https://forum.pine64.org/showthread.php?...#pid111949
I could hear a loud crackling buzz when starting the graphical session of Manjaro on my new Pinebook Pro. You may have luck with another distro. I don't hear that same buzz on a Fedora installation, but I haven't gotten sound working via the builtin speakers or headphones yet.
(08-20-2022, 03:33 PM)foobar Wrote: I could hear a loud crackling buzz when starting the graphical session of Manjaro on my new Pinebook Pro. You may have luck with another distro. I don't hear that same buzz on a Fedora installation, but I haven't gotten sound working via the builtin speakers or headphones yet.
Audio works on my system, with Armbian Jammy, for example. I noticed that the beginning of system sounds are cut off, so the device may be getting woken from sleep every time there's a new sound.
  Pinebook Pro Initial Impressions kunger 443 587,784 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,284 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 394 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 297 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 285 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 219 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 663 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 734 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,597 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,223 12-15-2023, 02:11 PM
