PineBook Pro seems to go to deep sleep, but doesn't wake up
(07-06-2023, 05:02 AM)jpalus Wrote:
(07-05-2023, 01:53 PM)kebab Wrote:
(04-26-2023, 02:49 AM)jpalus Wrote:
(04-21-2023, 03:45 PM)rik-shaw Wrote:
(04-19-2023, 03:42 PM)mensingma Wrote: I had the same issue and was able to resolve by unplugging the battery from the board temporarily.
Can you clarify? What distro, what bootloader, what kernel? I am happy to use any distro that will sleep / wake reliably :-)
That is finally the case for me with u-boot 2023.04 (ATF 2.8.0) and kernel 6.2 without any battery shenanigans. At least with eMMC, didn't try with NVMe.
Is this different from a standard u-boot installation? I'm trying to figure out if I should want to uninstall tow-boot and switch back to u-boot
I'm using "standard" mainline u-boot.
Gotcha. Do you happen to have any guide on how to go about installing that and replacing Tow-Boot? Smile I'm on a Gentoo installation that I sort of stumbled through into a working boot without fully being able to understand the process. I'm quite happy with Gentoo and don't want to move to a different distro, but would like to understand more about U-boot and have a functional hibernate and suspend ability. Currently I believe I have just got Tow-Boot on my SPI, which looks for the EFI image I've made with systemd-boot and then launches systemd-boot which then launches my system.
Tow-Boot is just u-boot with a slightly nicer UI, and a few more features (basically).
Cheers,
TRS-80
Protocols, not Platforms
  Debian on Pinebook Pro u974615 7 1,062 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,621 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,163 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,237 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 89,131 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,257 11-23-2023, 07:37 AM
  Sleep and external display - Are there any options? chris88233 7 1,737 09-04-2023, 09:03 PM
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,489 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Install deepin OS on pinebook pro wangyukunshan 4 1,596 08-07-2023, 01:12 PM
Last Post: myself600
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 667 07-13-2023, 05:21 PM
Last Post: owaspfap
