Pinephone craches after each call
Pinephone craches after each call and needs to be restarted
Hmm, can't reproduce it here. Are you at the latest version?
Sometimes the calling window stays fullscreen and hides window control buttons at the bottom of screen, so you can't close the window. In this case workaround was to open the Phone Settings window - then the window control buttons reappeared.
My experience with Manjaro PlaMo: https://forum.pine64.org/showthread.php?tid=15300
This happens almost every time a call is received or after a call is made. After a received call in the sound settings you might notice "dummy output". in most cases the phone must be rebooted. Other times you might see different settings such as default but the mic no longer responds. In that case you can log out and then log back in. The mic may work again. Saves a bit of time.
Arch Linux Phosh.
  systemic issue pinephone penguins_rule 3 429 04-02-2024, 11:52 AM
  link for supported pinephone os manjharo et all penguins_rule 2 247 03-19-2024, 10:36 AM
Last Post: penguins_rule
  new PinePhone upgrade issue WhiteHexagon 5 1,811 05-09-2023, 04:09 PM
Last Post: WhiteHexagon
  Can't add micro SD card to Pinephone thorensjubilee 7 2,550 02-27-2023, 10:21 AM
Last Post: mikehenson
  Pinephone Freeze kmsgli 14 7,513 02-04-2023, 08:35 PM
Last Post: Westslope
  Unable to hear caller or speak after answering a call danimations 5 4,045 11-01-2022, 02:06 PM
Last Post: X0X0X0X0X0
  Weird call... Eugo 3 2,023 09-15-2022, 11:20 PM
Last Post: Eugo
  manjaro-pinephone / plasma-mobile-dev: Update broken Uturn 32 29,499 07-28-2022, 12:40 PM
Last Post: johaennessen
  Call waiting issue kmsgli 22 14,798 06-24-2022, 06:02 PM
Last Post: kmsgli
  How to convert your pinephone to a palmtop now that you have the clamshell keyboard rotwang 3 3,083 05-09-2022, 08:29 AM
Last Post: ragreenburg
