link for supported pinephone os manjharo et all
Hi-
the images at the manjaro site only have a checksum and the site looks funny like no CSS styling is applied.  It is just a bunch of hyperlinks.
Mobian didnt have a way to verify either.
I am desperate for an image. Can someone point me somewhere there is a cool image i can use with the pinephone that is supported?
I like manjaro gnome but v16 aiin't workin.
thanks,
jim
manjaro's github page has .img files for each release, and .sha256 for each .img https://github.com/manjaro-pinephone/phosh/releases
okay that is awesome.
THANKS!
  systemic issue pinephone penguins_rule 3 426 04-02-2024, 11:52 AM
  new PinePhone upgrade issue WhiteHexagon 5 1,811 05-09-2023, 04:09 PM
Last Post: WhiteHexagon
  Can't add micro SD card to Pinephone thorensjubilee 7 2,542 02-27-2023, 10:21 AM
Last Post: mikehenson
  Pinephone Freeze kmsgli 14 7,503 02-04-2023, 08:35 PM
Last Post: Westslope
  How to install iptables extensions? I get "Extension owner revision 0 not supported" anon4 0 2,151 08-27-2022, 12:19 PM
Last Post: anon4
  Pinephone craches after each call neithan76 2 1,626 07-29-2022, 11:47 AM
Last Post: Chief
  manjaro-pinephone / plasma-mobile-dev: Update broken Uturn 32 29,488 07-28-2022, 12:40 PM
Last Post: johaennessen
  How to convert your pinephone to a palmtop now that you have the clamshell keyboard rotwang 3 3,079 05-09-2022, 08:29 AM
Last Post: ragreenburg
  "Emergency" terminal on pinephone (with default setup) altulke 5 2,693 05-03-2022, 12:42 PM
Last Post: altulke
Question Help installing Snaps on Pinephone running Manjaro ARM w/ Phosh danimations 2 1,898 04-07-2022, 06:02 AM
Last Post: danimations
